Still no luck with tracking down suspected vacuum leak. Anyone have any suggestions????
Old May 7, 2003 | 04:50 PM
hatchdrvr's Avatar
Default Still no luck with tracking down suspected vacuum leak. Anyone have any suggestions????
I've been trying to track down a suspected vacuum leak and have had no luck. I tried the carb cleaner trick with no noticeable results. I'm running out of patience with this and am open to ideas about what the problem could be. This is on a 2nd gen B16a SIR II in a '95 hatch and the car idles @ 1100 rpms with the idle adjust screw all the way down.
Thanks
Old May 7, 2003 | 06:03 PM
dfoxengr's Avatar
Default Re: Still no luck with tracking down suspected vacuum leak. Anyone have any suggestions???? (hatchdr
can you hear it?
Old May 7, 2003 | 06:06 PM
VTEC-DA's Avatar
Did it start doing it all of a sudden, or did it start doing after you did something to the car?
Old May 7, 2003 | 07:49 PM
bluice00's Avatar
spray 2+2 carb cleaner while the engine is at idle on all vacuum lines if the is=dle picks up u've found ur leak. it worked for my 00 SI
Old May 8, 2003 | 05:44 AM
hatchdrvr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">can you hear it?</TD></TR></TABLE>
No I can't tell. The valves on this motor need to be adjusted something fierce and btween that and the STR cam gears I can't hear a damn thing
Old May 8, 2003 | 05:45 AM
hatchdrvr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC-DA &raquo;</TD></TR><TR><TD CLASS="quote">Did it start doing it all of a sudden, or did it start doing after you did something to the car?</TD></TR></TABLE>
The motor just got put in last weekend and is bone stock except for STR cam gears.
Old May 8, 2003 | 07:40 AM
Davep's Avatar
Have you done the setting idle procedure in the helms?
EG9_808
Mar 2, 2007 11:23 AM
baddog
Oct 11, 2004 08:22 AM
slammin86
13
Jan 9, 2004 05:36 PM
hatchdrvr
May 11, 2003 12:05 PM
hatchdrvr
May 4, 2003 07:05 PM
