Ground Control & KYB AGX Install
Old May 7, 2003 | 04:31 PM
Canonm7's Avatar
Default Ground Control & KYB AGX Install
Hey guys,
I'm was working on my install today and I noticed something that was odd. I went to go put on the ground control springs onto the shock/strut and there is an unbelievable amount of space between the two. I know the ground control can be adjusted but isn't there suppose to be some contact between the spring and the seat? Anyone else encounter this situation?
Old May 7, 2003 | 04:46 PM
iam7head's Avatar
Default Re: Ground Control & KYB AGX Install (Canonm7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Canonm7 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys,
I'm was working on my install today and I noticed something that was odd. I went to go put on the ground control springs onto the shock/strut and there is an unbelievable amount of space between the two. I know the ground control can be adjusted but isn't there suppose to be some contact between the spring and the seat? Anyone else encounter this situation?</TD></TR></TABLE>
alot of people used to love groundcontrol when i came out but when they realize it's a sleeve type coilover, not a real coilover set up.
I haven't see any sleever coilover set up without gap when the car is jacked up
but dont worry about it..
Old May 7, 2003 | 05:19 PM
Canonm7's Avatar
Default Re: Ground Control & KYB AGX Install (iam7head)
Oh ok. So until I seat the car down there will be a gap? I can't even adjust it I took the hex bolt out and its like its glued on there. GRR!!! LOL Should've went the one piece route.
Old May 7, 2003 | 05:56 PM
iam7head's Avatar
when you drop your car, make sure the hat of the coil sit correctly..not slanted
Old May 7, 2003 | 08:28 PM
H22assbusa's Avatar
the ground controls should have come with 4 rubber insets that fill the gap between the struts and the sleves, mine did
Old May 7, 2003 | 08:55 PM
Canonm7's Avatar
Default Re: Ground Control & KYB AGX Install (H22assbusa)
Are you talking about the rubber seat that you use instead of your oem one of the top mount? or are you talking about a cone shaped item that I see in all the pictures with their stuff?
Old May 7, 2003 | 11:26 PM
AcCO12D95's Avatar
H22assbus
Is probably referring to the 4 black rubber donut shaped inserts, that go into the upper pillar-ball mount/upper strut mount.
I put mine in, and they are now ripping away, the things are weak.
Old May 8, 2003 | 06:27 AM
Canonm7's Avatar
Default Re: (AcCO12D95)
Yea they tell you to use the ones they supply instead of the stock. I saw the difference it was filmsy and the stock one was like a rock.
silentkill03
Oct 26, 2004 02:49 PM
tub_sephiroth
Jul 10, 2002 04:08 AM
TeamTooQuick
Mar 22, 2002 07:10 AM
Brewer
Feb 7, 2002 07:37 PM
PureTeg420
Oct 14, 2001 03:42 PM
