how to replace oil in the A/C compressor?
Old May 7, 2003 | 09:32 AM
dchi_t's Avatar
Default how to replace oil in the A/C compressor?
im about to install my A/C back in, when i took it out, all the oil leeked out so i was wondering if anyone out there knows how to replace the oil into the compressor and how much i should put in, as well as the amount of freon i should recharge it w/?? plz help...anyone?
Old May 7, 2003 | 10:16 AM
Stripped Honda's Avatar
99-0104
Default Re: how to replace oil in the A/C compressor? (dchi_t)
it should say on the car how much freon to add and the oil you need a oil injector .... and dont waste time installing freon unless you evacuate the system first or your wasting your time
Old May 7, 2003 | 11:09 AM
Stew Pidasso's Avatar
Call your local Honda Dealer and talk to the service person. They will give you this info...That's what I do anyway...
Old May 7, 2003 | 12:00 PM
YeuEmMaiMai's Avatar
this is what you MUST do if you really want your A/C to work and be trouble free for many years to come.
1. reassemble system.
2. replace acumulator/dryer. (it is STRONGLY RECOMMEDED THAT YOU REPLACE ALL O RINGS WHILE YOU ARE AT IT)
3. have the system evacuated and placed under a vaccume for at LEAST 8 hours preferably 12. this will ensure that as much moisture is removed from the system as possible.
4. have the system recharged with the proper amount of oil/refrigerent.
Old May 7, 2003 | 07:57 PM
dchi_t's Avatar
Default Re: how to replace oil in the A/C compressor? (YeuEmMaiMai)
all that u mentioned is only do-able from a mechanic's shop huh? i was hoping to do it myself to save some cash =D
Old May 7, 2003 | 08:23 PM
GZERO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">
If this is true, i haven't meet one person that does it, i hate this.
When should you do this kind of thing?
Old May 8, 2003 | 04:54 AM
JimBlake's Avatar
Default Re: how to replace oil in the A/C compressor? (GZERO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZERO &raquo;</TD></TR><TR><TD CLASS="quote">If this is true, i haven't meet one person that does it, i hate this.
When should you do this kind of thing?</TD></TR></TABLE>
To remove the non-condensible gases and the moisture from the system. Moisture will use up the dessicant in the receiver/dryer, and NCG will interfere with heat transfer in the evaporator and condensor. Air will promote corrosion in the system.
If you don't do it, your AC will still work, just not as good and not as long.
Old May 8, 2003 | 06:28 AM
GZERO's Avatar
Default Re: how to replace oil in the A/C compressor? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">
If you don't do it, your AC will still work, just not as good and not as long.</TD></TR></TABLE>
yeah, i believe you, is just that down here i haven't seen one store that does this
Old May 8, 2003 | 08:08 AM
JimBlake's Avatar
I figured any A/C shop has to be able to do this, in order to be licensed to use R-12. They hook up a vacuum pump to suck the old refrigerant out of the system for recycling, then again to suck air & moisture out after any repair...
All the shops that do A/C work around here can do that. Not 'stores' tho...
Old May 8, 2003 | 10:00 AM
Hour honda dealer will definately do it.......
3rdmdqm
Honda CR-V & Element
Apr 25, 2018 09:21 AM
jmanuel
Apr 29, 2015 03:16 PM
Nicefeet
Jul 10, 2012 09:45 AM
Gigem891
Jun 22, 2011 08:11 AM
aaj23
Jul 24, 2003 10:13 AM
