just got done with clutch install now noises???
official honda whore
well i just installed a clutch in my 91 rex Si........ i have installed a clutch b4 in a 95 civic but never in a crx, needless to say it took me 8 hours.... the other day i asked if i could use a flywheel from a 95 civic, and you all said yes that there the same, well now when im drivin it makes like a metal rubbing noise, what do i need to do to fix it, could it be the flywheel, or is it just the noise of breakin in the clutch, do i need to adjust the cable or soemthing? as soon as i put the clutch in it doesnt make the sound anymore, what could it be?
oh by the way , when i was doin the lower ball joint i realized that the lock nut doesnt like to go back on after it was beaten to get the joint to break loose.. so what i did is i threaded it onto the bolt that goes to the bottom of the shock and str8ened the threads out before tryin to put it back on the ball joint and havin a chance of ruining it. i jus thought id throw that pointer out for anyone who has had a problem with the lockin nut
its brand new, is there someway i didnt put it in right?? how was it supposed to go, is the spring have one side that clips into the side of the throwout bearing???
If I recall there was no real wrong way you could put on that throwout bearing, it was congruent so it wouldn't matter. Maybe you forgot to grease it up or something?
