HELP!!!! Cannot budge crank pulley bolt!!!
Old May 6, 2003 | 05:20 PM
smithbling's Avatar
Default HELP!!!! Cannot budge crank pulley bolt!!!
I have tried an air gun
Breaker bar
Broke an extension also
DAMN!!!!!
The problem seems to be that I cannot stop the crank pulley from moving slightly and therefore cannot break the bolt. the helm's manual says to put a screwdriver on the flywheel but my tranny is still connected. What the hell can I do??????!! !!!
Old May 6, 2003 | 05:31 PM
dbuelow's Avatar
Default Re: HELP!!!! Cannot budge crank pulley bolt!!! (smithbling)
have you tried an impact wrench?
Old May 6, 2003 | 05:37 PM
smithbling's Avatar
Default Re: HELP!!!! Cannot budge crank pulley bolt!!! (dbuelow)
Impact gun = air gun
Where is the cover for the flywheel so I can jam a screwdriver in there?
Going to home depot to get a fence pole HAHA! for leverage that is.
Old May 6, 2003 | 05:50 PM
CRXBart's Avatar
Get a GOOD impact wrench like an Ingersol Rand 3/8" I haven't found anything mine won't budge or break. I've used cheap impacts before and they just don't add up. Mine even out performs my boss's big bad Snap On unit. It should though, mine did cost more.
Old May 6, 2003 | 06:32 PM
smithbling's Avatar
Hmm, I have a good SNAP ON unit too, however i think I may need a 450 TQ gun or something?
Old May 6, 2003 | 06:43 PM
GroundZer0's Avatar
Default Re: (smithbling)
damn, this was the hardest thing i ever had to take off my car, use a HUGE breaker bar, and alot, ALOT of force, i used my whole body on top of the bar jumping up and down.. jesus lord.. i wish you luck.
88rexdxa6ed's Avatar
i just spent all day trying to break mine loose, the only way i could get was by putting 2 motor mount bolts right next to each other in the pulley hole and then wedging a jack handle between them, then turn the pully till the jack hand hit the control arm. then you can break the bolt loose with a big breaker bar.
Old May 6, 2003 | 07:19 PM
smithbling's Avatar
Hmm with my weight a 2.25 ft breaker bar will get me 500 ft'lbs of torque. Should be enough!!!
Fricking THING!!!!
Old May 6, 2003 | 07:23 PM
MADEINIRAQ's Avatar
i made a pulley holder... or you can buy one.. best solution i can think of
Old May 6, 2003 | 08:24 PM
STHPERFORMANCE's Avatar
Default Re: (madeiniraq)
i tried with my air gun and it wouldnt come loose...
SO WHAT I DID WAS.............
1. Had my dad sit in the driver seat and mash the break pedal then i took a breaker bar and a hollow pipe to put more leverage on the bolt and she came right off like amayo jar lid......... Dont stick a screw driver in your flywheel.....Try my method and she should come right off......
Old May 6, 2003 | 08:30 PM
unabonger's Avatar
I tried everything, my impact gun was too weak so i took the whole motor to a shop and they blasted it off in a second. I suggest using a really powerful impact wrench such as IR titanium or something with lots of torque or just take it to a shop like I did. They have bigger air tanks and if that dont work they also have nitrogen tanks for the job.
Old May 6, 2003 | 08:53 PM
redzcstandardhatch's Avatar
something different
Default Re: (unabonger)
i got a gun from my buddies dads shop that was a 3/4 drive (huge) that had 900 lb/ft of torque.......got it off in a second. our 450 gun wouldnt do it, and we tried for a LONGtime
Old May 6, 2003 | 09:49 PM
civickiller's Avatar
Default Re: (redzcstandardhatch)
my 450ft/lbs air gun took it off. like with at the stock compressor setting it would come off, they say to set it at 100psi for my gun. well i just turned it up to 120 on the compressor regulator and bam spun it right off
Old May 6, 2003 | 11:19 PM
sporkcrx's Avatar
Default Re: (civickiller)
I did mine with the engine out of the car...I put a piece of wood inbetween the crank counterweight and a good piece of the block, then used a huge *** elephant impact gun.
Old May 7, 2003 | 05:44 AM
slowpokesi's Avatar
Default Re: (sporkcrx)
for future refrence you can remove the starter to have access to the flywheel while the motor is connected,
you can try having someone mash the brakes and put the car in 5th gear, or you can buy the honda crank pulley tool for a measley 50 bucks. that tool is the bomb
Old May 7, 2003 | 05:45 AM
sporkcrx's Avatar
Default Re: (slowpokesi)
What motor is the tool for? I don't think there is a tool for the d16a6???
Old May 7, 2003 | 06:02 AM
yellowcrx1991's Avatar
This has been covered a lot of times, use the search button.
Heres some info, never done it myself though.
http://www.crxsi.com/resources..._belt/
Old May 7, 2003 | 06:45 AM
88_SC_CRX_Si's Avatar
New User
Some peeps have ended up taking it to a shop, and having them break it loose (if it's still drivable). Then just torquing it back down enough, to get it home.
They can be torqued anywhere from 80 something to 136+ depending on the year.
Old May 7, 2003 | 06:53 AM
slowpokesi's Avatar
there is 2 diffrent ones, one for the b series, and one for the d
the bseries you get the hex tool
the d series use a punch - like tool
Teg_93
Jan 15, 2007 06:55 AM
smithbling
May 13, 2003 01:18 PM
warwagon
Mar 10, 2003 09:29 AM
BoostedED9
Jun 16, 2002 06:45 AM
