OEM vtec pistons on LS rods
you need to narrow the small end of the rod to use vtec pistons. its about .100" I think...dont try to do it yourself. I recommend getting the rods re-shotpeened after the narrowing procedure.
ps What pistons did you go with?
um.............correct me if i am wrong but i am under the understanding that stock first gen pr3 b16a pistons will bolt up no problem and up the compression a bit.
skoodles2k6
Sep 18, 2007 09:27 PM
