Availability of 97spec JDM ITR 4lug rotors...and other significant parts.
Ok guys, need a hand here.
Lets say, if one was to buy a 4lug ITR. How dificult is it to find rotors for them...Are they available at any parts store?? or would I have to order them specially.
Lastly is there any possibility that I could use a rotor from another car.. for example a 4th gen vtec lude, w/some type of Legend/NSX caliper setup??
I know all USDM ITRs are 5lug, this is the only reason I'm asking. (which Im sure the vast majority...if not all of you already know...)
TIA guys.
any info/insight is greatly appreciated.
TIA guys.
the 4 lug pattern is i beleive 4X114 or somthing like that. i think the accord 4 lug and prelude 4 lug are the same. but im not sure.
I have 96Spec ITR suspension (i do not believe the 97 was 4 lug), It is 4x114.3 and I would not buy one again because of a total lack of knowleged about what fits and what one can do with it. Search 96 ITR in the EG forums and you'll see what I mean. I am having big problems geting any good information about what fits. I don't believe anything I have been told so far. If anyone can proove me wrong please do, it would be a big help. I need wheel bearings and hubs. Prelude and accord are the same bolt pattern, but totaly different parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BCRUZ »</TD></TR><TR><TD CLASS="quote">92-96 lude calipers and rotors fit. I just found that out.
uggh
so you mean the vtec rotors right?? anyone else have any insight??
what are the differences between GSR/ITR rotors??
pardon my lack of knowledge.
TIA
</TD></TR></TABLE>uggh
TIA
I found this at least.
here is the link..
https://honda-tech.com/zerothread?id=482804
EX and GSR both have 10.2" rotors, however the GSR has larger calipers
ITR has 11.1" front rotors with large Accord calipers
anyone know how much truth there is to this???
here is the link..
well first off.. the GSR are 4 lug, the US ITRs are 5 lug. this guys 4lug JDMs are a different bolt pattern than the 4 lug GSR's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest »</TD></TR><TR><TD CLASS="quote">well first off.. the GSR are 4 lug, the US ITRs are 5 lug. this guys 4lug JDMs are a different bolt pattern than the 4 lug GSR's</TD></TR></TABLE>
Ok...so GSR is 4x100. and ITR is 4x114.3??
Does anyone know what he means in the post above by "large accord calipers"
TIA
TIA
REALLY?!? hell yea, that is great. I hope your right on that. Where did you get this info???
related links that I know of:
https://honda-tech.com/zerothread?id=456988
https://honda-tech.com/zerothread?id=496577
https://honda-tech.com/zerothread?id=489433
</TD></TR></TABLE>REALLY?!? hell yea, that is great. I hope your right on that. Where did you get this info???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhucNguyen57 »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=489433 </TD></TR></TABLE>
If that is true...than the NSX/Legend calipers can work as well..
This may end up being a trial and error thing..
You might wanna purchase some calipers (measuring device.) get the dims of the hubs, and then go to autozone and measure all the lude/accord hubs as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsludefosho »</TD></TR><TR><TD CLASS="quote">
I wish someone could tell me. I really dont know. I need more money to play around with so that I can find this stuff out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">his may end up being a trial and error thing.. You might wanna purchase some calipers (measuring device.) get the dims of the hubs, and then go to autozone and measure all the lude/accord hubs as well.</TD></TR></TABLE> yea, I used to work at the AZ. I plan on doing that.
There is something about S13 brakes fitting, and i have a JDM PS13 clip laying around. I'm going to see what I can fiugure out about that in the next couple weeks.
The Accord WAGON uses the same caliper as the ITR. You may want to check the Prelude VTEC rotor. I have to redrill the rotors (prelude VTEC) to 4x100 to fit my GSR lugs.
Ok, so when you say Accord WAGON, do you mean USDM, as in I could get it here no problem??
If all else fails we could end up using "shims" to get the lude vtec rotor to fit on Legend/NSX calipers..Im also pretty confident the Legend GS rotors fit w/out shims...but would need to be redrilled..
So the prelude rotors WILL work for 96 ITR hubs and calipers? I need to replace the REAR rotors because one of the rears is like 8mm bigger than the other one for some reason and I need to know for sure what will work. HELP!!!!!!!
Son of a... so no other rotors will work (::FOR THE REAR:: )?? I have to get prelude calipers and brackets to make new rotors fit? Do you of any aftermarket manufacurer that make rotors for the 96-spec ITR hubs??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote">So the prelude rotors WILL work for 96 ITR hubs and calipers? I need to replace the REAR rotors because one of the rears is like 8mm bigger than the other one for some reason and I need to know for sure what will work. HELP!!!!!!!</TD></TR></TABLE>
So you are saying on of your rear rotors is bigger than the other???
If all else fails you might be able to get a machine shop to make some for you..It may be pretty pricy though.
I might have found us some help...look at this thread just up from us
https://honda-tech.com/zerothread?id=504042
YOu so cal guys, please help out the rest of us and go talk to this guy about brakes, wheel bearings, upgrades and anything else you can think of related to this suspension. I think we all need help with finding maintenance parts for this suspension. Does this guy post on H-T, if so I think we should post something in the RR/AutoX forum. That is like the Honda Challenge home.
edit: i tried https://honda-tech.com/zerothread?id=504424
Modified by PhucNguyen57 at 12:21 PM 5/13/2003
