Quick Integra front bumper removel
Old May 6, 2003 | 02:30 PM
tub_sephiroth's Avatar
Default Quick Integra front bumper removel
I'm doing my intake install and trying to remove the front bumper. How do you take off those rubber phillips screws on the top of the bumper? No matter how hard I try to unscrew them, they won't move at all and only strip! This is so frustrating.
Old May 6, 2003 | 02:40 PM
sackdz's Avatar
Default Re: Quick Integra front bumper removel (tub_sephiroth)
With the proper sized screw driver. If you strip them too bad you'll have to drill them off. Impact driver would probably work pretty good also.
Old May 6, 2003 | 07:16 PM
mr_mbuna's Avatar
Default Re: Quick Integra front bumper removel (sackdz)
No, this is WRONG. These screws are very soft and you will cry yourself to sleep trying to unscrew them with a screwdriver once they start stripping. Get some vice grips and grip them around the head and turn >> voila!
Ben
Old May 6, 2003 | 07:51 PM
sackdz's Avatar
Default Re: Quick Integra front bumper removel (mr_mbuna)
What's so WRONG? It's a screw, you use a screwdriver when you can. If they start stripping, use and impact screwdriver preferably or vice grips like you said.
Old May 6, 2003 | 11:10 PM
bearingburner's Avatar
use a stubby screw driver or a #3 philips driver.
Old May 7, 2003 | 04:18 AM
speedymon's Avatar
Default Re: Quick Integra front bumper removel (bearingburner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bearingburner &raquo;</TD></TR><TR><TD CLASS="quote">use a stubby screw driver or a #3 philips driver.</TD></TR></TABLE>
And PB blasta!
Old May 7, 2003 | 07:41 AM
untitled's Avatar
Default Re: Quick Integra front bumper removel (speedymon)
spray the bolts with PB let sit for a day, spray them again then go at them with vice grips. it will work garuateed. i spray PB on LCA bolts everyday threee days before i tried taking the bolt off and it came off with the greatest of ease.
Old May 7, 2003 | 09:24 AM
mr_mbuna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">What's so WRONG?</TD></TR></TABLE>
Only wrong because these screws are notorious for stripping. If you can use a screwdriver with no problems, then good. But all the shops I've talked to use vice grips. Just remember my experience before I knew about vice grips, and it wasn't a happy memory. Good luck.
Ben
dingobat
Paint and Body
May 17, 2007 09:15 AM
crashN2u
10
Jul 16, 2004 05:49 PM
soviet
20
Jun 5, 2004 05:21 PM
NuclearB18B
May 5, 2003 03:00 PM
Autohow
Sep 6, 2001 09:46 PM
