what size is the crank pulley tool? thining of making my own tool?
Old May 6, 2003 | 02:11 PM
Dan GSR's Avatar
Default what size is the crank pulley tool? thining of making my own tool?
what is the large hex size?
I know the inner bolt is a 19mm...but what about the pulley
reason I ask is i'm thinking of making my own pulley tool
Old May 6, 2003 | 02:41 PM
sackdz's Avatar
Default Re: what size is the crank pulley tool? thining of making my own tool? (Dan GSR)
I'll find out for you tonight. That is if you promise to make me one too.
Old May 6, 2003 | 02:49 PM
IN VTEC's Avatar
I measured it out to around 1.973" or 50.48mm. Mine fits a little loose in the crankshaft pulley tho, so maybe 51mm would be better.
Old May 7, 2003 | 09:44 PM
Dan GSR's Avatar
up
Old May 8, 2003 | 12:53 AM
Slurp56's Avatar
the guy that made mine said he used a 48mm nut. just slightly smaller than the 50mm crank pulley hole.
Old May 8, 2003 | 06:43 AM
IN VTEC's Avatar
Default Re: what size is the crank pulley tool? thining of making my own tool? (Slurp56)
How snugly does your's fit? 48mm seems a bit too small.
I tested my holder on a spare crank pulley I have laying around and it fits a tad bit loose. You can probably get 4 degrees of rotation on it before it actually locks on the side walls.
Maybe my dial caliper is off. I'll break out the micrometer later on.
Old May 8, 2003 | 06:48 AM
JimBlake's Avatar
Default Re: what size is the crank pulley tool? thining of making my own tool? (IN VTEC)
The Helm book says the tool is 50mm (= 1.9685")
Old May 8, 2003 | 06:52 AM
tilt's Avatar
I just measured my moroso tool. If this ruler im using is accurate, it's 50mm. hth
BLKFLSH
Apr 10, 2011 01:54 PM
wushubrian
Dec 27, 2006 11:39 AM
Finest
Nov 12, 2002 09:52 AM
jasonb
Jun 8, 2002 01:40 AM
