ls crank in a b16?
makes it a 1.8-2.0 depending on the bore of the block you need custom rods and pistons, im going thru http://www.hankthecrank.com for my B16 stroker kit cept im using the 87.2mm B18C crank instead of the 89mm LS crank hth.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra »</TD></TR><TR><TD CLASS="quote">lets say i had a first gen b16. cant the ls rods and crank bolt up without hassle? i thought pr3 pistons boled to the ls rods no problem?</TD></TR></TABLE>
yea the rod journals are the same on the b16 and b18a/b but you have to remember the B16 is shorter then a B18 block so using LS rods would have the pistions sitting out the deck.
B16 rods are 134mm and i believe LS rods are 137mm
so a b18a crank will bolt up to b16a rods and pistons with no cleareance issues. just str8 bolt up. you dont have to machine the block or anything?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra »</TD></TR><TR><TD CLASS="quote">so a b18a crank will bolt up to b16a rods and pistons with no cleareance issues. just str8 bolt up. you dont have to machine the block or anything?</TD></TR></TABLE>
No you still need a piston with the wrist pin moved up for enough clearance.
im not sure on the mm i have them written down somewhere in my messy *** room.
the deck height is taller on the b18 so to fix that you would have to get either a deck plate or custom rods to make it work...even if u do the custom rods the rod stroke ratio might be a problem.
CTR_B
Oct 17, 2008 04:19 PM
