Picking up a b18a for $550 CDN, what should i do?
Old May 5, 2003 | 10:36 PM
Toptul_Honda's Avatar
New User
Default Picking up a b18a for $550 CDN, what should i do?
SOmeone is selling a b18a block and im thinking of buying it and working on it until i have the funds to buy a complete SIR swap so i can use the parts minus the shortblock to make and LS vtec.
1) Keep it LS/Vtec
2) Boost it
3) N/A (built bottom end)
What are teh advantages and disadvantages of each?
I want something reliable and VERY powerful
Old May 6, 2003 | 11:41 AM
joshwhe's Avatar
#3 its reliable and powerful. put some pr3 pisotns in it.. some 403 or = cams have the head cleaned and drive it forever
Old May 6, 2003 | 12:09 PM
DJ_SaNdOz's Avatar
Default Re: (joshwhe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshwhe &raquo;</TD></TR><TR><TD CLASS="quote">#3 its reliable and powerful. put some pr3 pisotns in it.. some 403 or = cams have the head cleaned and drive it forever</TD></TR></TABLE>
i agree that this will be your best plan of action- w/ all that torque & aftermarket cam's your ef will feel STRONG & that's a helluva deal
Old May 6, 2003 | 01:22 PM
Malgerus's Avatar
Default Re: (dj_sandoz)
I wouldn't do an LS/VTEC unless you know EXACTLY what you're doing, and have big $$$ to do it, especially here in Canada. I would just build up the LS and keep it non-vtec.
Old May 7, 2003 | 07:32 AM
New User
Default Re: (Mr. S)
i was thinking of getting someone to help me out with this build.
Picking up a complete b16a swap as well using all those parts for the swap.
Using the head and pistons
Old May 7, 2003 | 07:55 AM
raene's Avatar
Default Re: (G2-Rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2-Rex &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking of getting someone to help me out with this build.
Using the head and pistons </TD></TR></TABLE>
Feel free, but I've yet to see an LS/VTEC that hasn't blown up in short order. I've HEARD of a couple, yes, but all the local ones went blooey rather fast.
Old May 7, 2003 | 08:01 PM
New User
Default Re: (raene)
really? And why would that be a local issue?
Old May 7, 2003 | 08:08 PM
Malgerus's Avatar
It's not really a local issue, it's just that all the LS/VTEC swaps that the odd guy owns around here either burn oil or straight blow up. I've seen it myself. If I were you, I would get a REPUTABLE shop to build one for you, even if you have to get it shipped to your door from the states. It's not worth the pain in the *** to have a motor blow up at the track and have to be towed home.
Old May 7, 2003 | 09:36 PM
rusty89si's Avatar
just turbo the b18a. get a blockgaurd, get a port & polish, new gaskets/water pump/feul pump, and bigger injecotors and youll be fine as long as you keep the boost low if its a dd.
civichbb18
Jun 1, 2006 05:38 AM
blaxican05
18
Nov 27, 2005 08:07 AM
Cyphear
Sep 27, 2005 04:25 PM
blacksheep
Feb 10, 2004 01:38 PM
