Forced induction Zdyne users...Show me your maps!...
I am currently working on my base map which I will use only for the drive to the Dyno, and my base run.
This is going to be a Stock block ZC running 10psi from a precision SC32. I hope to get around 200+ whp at 10psi on pump gas and 450cc DSMs.
I would just like to see some of your D series fuel and igntion map's to get an idea of what others are running. Right now I have tuned Ricky Crows ZC tune a little richer (larger turbo), and thats about it.
Thanks for any input!
Bryson
Bryson
Bryson Im also using the Ricky Crow with a little richer mixture. If you would like I can send it to you when I get home from work
Did you end up dynoing your setup with your new Zdyne? I can't remember if you did...?
The problem is that I'm going to be using a quite large T3/TO4E (.63 Exhaust with 54 trim compressor) which is good for almost 450hp. No one runs a really big T3/T4's on a ZC. As far as I know, I'm the only one doing so with a stock block. This makes it hard to find tunes that have richer settings per psi of boost (more flow per PSI because of the turbo's size).
I would run a smaller turbo, but I have future plans...
I imagine with Tinker's equal length mani, and dawes device boost controller, I should have full boost around 4500.
Modified by Bryson at 12:10 AM 5/7/2003
These are all that I've made from the base maps Z-Dyne sent with the unit...
http://home.midsouth.rr.com/jdmcivic/Z-Dyne/
Enjoy.
Enjoy.
Truffle Shuffle
Mar 2, 2002 09:09 PM
