irratic idle
Old May 5, 2003 | 09:13 PM
2faz2paz's Avatar
Default irratic idle
ok i am having one hell of a problem with my car. my idle is really bad. flucuates from 2000-3000 then down to 1500-2500 or so. i have changed all teh gaskets and made sure they are sealed right and have no vaccum leaks. and i jumped my ecu or whatever and am getting codes 3-map sensor 14 iacv sensor 71 cyl1 misfire and 72 cyl 2 misfire. anyone know what my problem would be. i would disconnect my map and iacv sensors and my idles would stop and sit at 2k or so. but it would sound really messed up. it is getting really annoying cux i havent been able to figure this out. i also dont have any of my tranny sensors in the tranny right now if that could make a difference. thanks in advance for any help
Old May 6, 2003 | 04:30 AM
2faz2paz's Avatar
Default Re: irratic idle (2faz2paz)
ttt.... anyone?
Old May 10, 2003 | 07:04 PM
92HB_HB's Avatar
ditto
Old May 10, 2003 | 08:49 PM
icelarry27's Avatar
Default Re: irratic idle (92HB_HB)
soo many people have had problems with idol....use the search, your gauranteed to find something for your problem.
Old May 10, 2003 | 09:40 PM
Shaun's Avatar
Default Re: irratic idle (icelarry27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by icelarry27 &raquo;</TD></TR><TR><TD CLASS="quote">soo many people have had problems with idol....use the search, your gauranteed to find something for your problem.</TD></TR></TABLE>
this is true
Old May 11, 2003 | 05:33 PM
integra69r's Avatar
did you drain the coolent?
i was told that will work. my teg does the same thing. i went out and bought a new iacv and put that on. that didn't do it. so it has to be the coolent. i have no time to drain mine so i couldn't tell you if that does work or not.
Old May 11, 2003 | 08:30 PM
NiiS's Avatar
Default Re: irratic idle (integra69r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra69r &raquo;</TD></TR><TR><TD CLASS="quote">did you drain the coolent?
i was told that will work. my teg does the same thing. i went out and bought a new iacv and put that on. that didn't do it. so it has to be the coolent. i have no time to drain mine so i couldn't tell you if that does work or not.</TD></TR></TABLE>
More specifically, bleed the coolant you already have before you start throwing parts at the car...Just a thought
Old May 15, 2003 | 10:10 PM
DragonTLS's Avatar
try to replace the idle control valve
B17DA-SON
Feb 5, 2010 09:23 PM
B18cHatch06
Dec 30, 2005 09:30 AM
S2000Forsale
Honda S2000
18
Oct 6, 2005 06:33 PM
J_Trez
Apr 29, 2005 04:46 PM
..::91TEG-G2::..
Jan 26, 2005 10:01 AM
