obd1 distribuitor or obd2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ronman92 »</TD></TR><TR><TD CLASS="quote">im doing a obd1 ecu upgrade for my 90 crx with a b16 i need a distribuitor does it have to be a obd1 distribuitor or obd2 does it matter help</TD></TR></TABLE>
If you are doing an OBD1 upgrade, you will need OBD1 distributer, fuel injectors and ECU. Each OBD level has different ECU plugs. Your car will also need an OBD1 ECU conversion harness or you could make one of your own.
You will also need to modify your engine harness too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ronman92 »</TD></TR><TR><TD CLASS="quote">yea but does it matter what distribuitor i use can it be obd1 or obd2 b series does it matter</TD></TR></TABLE>
I've never dealt with OBD2, but I would assume you need an OBD1 distributer as long as your using an OBD1 ECU.
h22_crx
Mar 4, 2007 02:17 PM
quikB18B
Apr 14, 2002 08:48 AM
