02 sensor problems!!! Make it stop please!!!1
Old May 4, 2003 | 05:18 PM
DEVIN22CBR's Avatar
Default 02 sensor problems!!! Make it stop please!!!1
Good lord. ....I went all out and finnaly got a Integra harness for my car ...92 CX with a B18A1 ...I have a 4 wire o2 sensor ..so its plug and play right ...Ok so i plug it in ..No codes ....started up good ...After a few mins I drove ti down the road ...Going up a hill in 2nd it started to make a "studder studder studder" then pick up and go normaly agian. It runs like total *** right now ...Then after i came to a stop ..It dropped to about 100 or 200 rpms ...about died how car rattled then the idle raise back up and it drop agian and kept doing so ...So I studdered it back home frustrated and does anyone know whats wrong ?
Old May 4, 2003 | 05:34 PM
dfoxengr's Avatar
Default Re: 02 sensor problems!!! Make it stop please!!!1 (BALL BAG)
damn my suggestion didnt work? if this is a new swap, meaning u just put it in, change your fuel filter...
Old May 4, 2003 | 05:37 PM
preluder's Avatar
Default Re: 02 sensor problems!!! Make it stop please!!!1 (hybridvteceg)
i have the same ****** problems too fuel filter? hmm ill check that and the plugs.
Old May 4, 2003 | 06:03 PM
DEVIN22CBR's Avatar
Default Re: 02 sensor problems!!! Make it stop please!!!1 (preluder)
Ok heres my new status ...Drove the car with it un plugged ran normal very strong . Plugged it up on the way back to the house. ...ran like total **** wouldnt idle at all dropped to 100 then up ...alot slower ...I have no clue fella's
Old May 4, 2003 | 07:41 PM
bearingburner's Avatar
upgrade your fuel pump.
Old May 5, 2003 | 04:09 AM
DEVIN22CBR's Avatar
Default Re: 02 sensor problems!!! Make it stop please!!!1 (bearingburner)
Thats not the problem ....If you read above it runs fine without the o2 sensor plugged up just shitty MPG ...When I plugged it back up the symptoms started back up again.
Magik123
Jun 13, 2007 05:10 PM
Magik123
Jun 3, 2007 12:29 PM
VvPeachyvV
Jun 24, 2005 05:20 AM
90gs
Apr 27, 2005 03:13 PM
cr-x si
Mar 18, 2003 02:30 PM
