? on JDM LSD trannys
Old May 4, 2003 | 03:36 PM
NoLipRacen's Avatar
Default ? on JDM LSD trannys
i want an LSD tranny and ive seen a few on ebay goin for $500-600, and my question is, is the LSD inside of that tranny or is it a separate piece? because i want limited slip but i dont want to drop a grand for a new quaife. like this one
http://cgi.ebay.com/ebaymotors...33733
just the way they worded the discription makes it sound like it only fits cars with LSD. thanks
Old May 4, 2003 | 03:39 PM
4bidden's Avatar
Default Re: ? on JDM LSD trannys (LudeTuner)
Definately dont buy that. YOu can see the serial sticker is gone which also shows you which model the tranny is. I'd also watch out for people who are very clean about it being sold AS-IS.
Old May 4, 2003 | 03:59 PM
satan_srv's Avatar
Well to answer your question the LSD is in the differential which is the in the casing to the right in this pic of my euro-r tranny
this pic is no good, but if it is LSD you should be able to see straight through the differential to the other side..
And 4bidden is right, I wouldn't buy a tranny without one of these
Tranny codes
Old May 4, 2003 | 06:42 PM
Allstar's Avatar
New User
Default Re: ? on JDM LSD trannys (satan_srv)
it should look like this...
"M2B4" is the stamp for a JDM LSD tranny. I would pass on the ebay tranny and buy it from someone reputable. Even if it is an lsd the gears could be shot and theres no way to tell by looking at it.
Old May 5, 2003 | 03:55 PM
NoLipRacen's Avatar
Default Re: ? on JDM LSD trannys (Allstar)
how much can i find one of those for, or a used 4th gen w/ lsd? and where can i find them?
Old May 5, 2003 | 11:11 PM
caLiH22A's Avatar
go to your local junkyard, around here, junkyard's get front clips of preludes and other cars from japan.
Old May 6, 2003 | 07:55 PM
NoLipRacen's Avatar
Default Re: ? on JDM LSD trannys (caLiH22A)
maybe in cali, but the yards out here only have parts for '80s mini vans. unless you want to look for me...
Old May 6, 2003 | 07:59 PM
ziggity's Avatar
actualy a type SH tranny you can see right throug also so that theory will not always work but you can always check the tranny code
gursh d
Jul 24, 2007 06:56 AM
H23Si_PRELUDE
Dec 21, 2005 05:07 PM
crzyfool24
24
Apr 2, 2004 10:33 PM
CRX A4
Apr 5, 2003 04:04 AM
