Any ideas on how to remove the valve stem seals???
Old May 3, 2003 | 01:16 PM
CBR's Avatar
CBR
Default Any ideas on how to remove the valve stem seals???
Tearing apart my H22A head. Need something other than long pliers to remove the valve stem seals. Is there a special tool that I can buy. Any other ideas?
Thanks!!!
Old May 3, 2003 | 01:20 PM
IN VTEC's Avatar
Default Re: Any ideas on how to remove the valve stem seals??? (ChurchBoyRacer)
Stem seal pliers.
I just use vice grips.
Old May 3, 2003 | 03:12 PM
sporkcrx's Avatar
Default Re: Any ideas on how to remove the valve stem seals??? (IN VTEC)
I bought the snap on tool. $40, but that's ok because I'm a baller.
Old May 3, 2003 | 03:51 PM
InevitableRace's Avatar
I have some valve seal removers for sale...email me for pic ..eg6civicsi92@aol.com...
Old May 3, 2003 | 06:01 PM
CBR's Avatar
CBR
Default Re: Any ideas on how to remove the valve stem seals??? (sporkcrx)
Do you know the Snap-On item number???
Old May 3, 2003 | 10:41 PM
IN VTEC's Avatar
YA8230
Old May 4, 2003 | 07:56 AM
94CivicSi's Avatar
needle nose pliers work well for me. You want to use just enough pressure to grip the body of the seal. If you grip them too hard, you'll defrom the seal and make it much harder to get off. Put a litte degreaser on a rag and wipe the oil off the seal too to give you a better a better grip.
Old May 18, 2003 | 07:57 PM
MisterB's Avatar
Default Re: Any ideas on how to remove the valve stem seals??? (94CivicSi)
is it possible to replace the seals while the head is still on the block for a b16a
Old May 19, 2003 | 06:26 PM
CBR's Avatar
CBR
Default Re: Any ideas on how to remove the valve stem seals??? (MisterB)
I'm sure you can, it just gets a little tricky with the valve in the way.
lude98SH
Jul 26, 2007 05:39 AM
itr1244
Apr 10, 2006 07:39 AM
RACEPAK
11
Dec 11, 2005 03:03 PM
Red D Dragon
May 5, 2005 10:16 AM
Space Boy
May 30, 2002 12:46 AM
