Pre-steps for installing turbo next weekend
Old May 3, 2003 | 01:00 PM
tegasaurus's Avatar
Default Pre-steps for installing turbo next weekend
I am trying to get all the pain in the neck stuff out of the way now, like getting all the nuts/bolts to make sure that i don't have to goto hardware store every 10 minutes. And one of the things i got ahold of was a spare LS oil pan.
So i plan on drilling the oil pan fitting now. my quetsion is where?
I'm thinking in one of the red circles (between the bolts that mount it on so i won't have trouble putting those bolts back in). But i noticed my buddy (tegtuner) has his oil return welded where the blue is (his was professionally installed). KEep in mind i have earls fittings.
thanks,
Ryan
ps, yes my hand IS gloved
Modified by tegasaurus at 2:17 PM 5/3/2003
Old May 3, 2003 | 01:21 PM
accordfreak's Avatar
Default Re: Pre-steps for installing turbo next weekend (tegasaurus)
i had mine installed by drag-- they put the hard line all the way to the left
no problems at all.
Old May 3, 2003 | 04:48 PM
tegasaurus's Avatar
bump
Old May 3, 2003 | 04:53 PM
Trac226's Avatar
If I had to, i'd put it through the far right spot. But, I would highly recommend you to just wait until you have the manifold and downpipe on the car to do a test fit, everyone's set up is a little different and you want the correct angle in your oil line. Also, it doesn't take that long to drill the hole and get the pan up there.
Old May 3, 2003 | 04:58 PM
B18EG6's Avatar
Default Re: Pre-steps for installing turbo next weekend (Trac226)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trac226 &raquo;</TD></TR><TR><TD CLASS="quote">If I had to, i'd put it through the far right spot. But, I would highly recommend you to just wait until you have the manifold and downpipe on the car to do a test fit, everyone's set up is a little different and you want the correct angle in your oil line. Also, it doesn't take that long to drill the hole and get the pan up there.</TD></TR></TABLE>
I agree with him. This is a vital part of the whole kit, and its best to test fit to see where the right spot is. BUT, here is my reutrn.
Old May 3, 2003 | 08:04 PM
DR. ON POINT's Avatar
Banned
Default Re: Pre-steps for installing turbo next weekend (B18EG6)
depends on the manifold that u run. Which manifold u got? Cant go wrong with either of ur red circles.
Old May 4, 2003 | 02:39 PM
tegasaurus's Avatar
Default Re: Pre-steps for installing turbo next weekend (DR. ON POINT)
im running a maxrev manifold, max rev downpipe and a t3/to4e with .63 exhaust .60 comperssor... essentially its a maxrev setup (minus the i/c, the piping, and the fuel management, or lack there of).
-ryan
Old May 4, 2003 | 03:17 PM
nerdsports's Avatar
you should test fit it. it'll be more accurate!
Old May 4, 2003 | 06:05 PM
phresh_5's Avatar
Default Re: Pre-steps for installing turbo next weekend (nerdsports)
Here' where I put mine:
96vtecI4
Mar 10, 2007 08:40 PM
B18 CYA
Mar 2, 2006 08:18 PM
DMax013
Apr 7, 2005 05:56 AM
SPOON_BeIgHtEeNsEe
Apr 11, 2003 09:36 PM
The Poopsmith
Mar 11, 2003 06:57 AM
