What size drill bit would I use for a -10an bulkhead fitting?
Old May 3, 2003 | 05:41 AM
Stew Pidasso's Avatar
Default What size drill bit would I use for a -10an bulkhead fitting?
The biggest I have is 1/2 inch drill bit. I need to drill my oil pan for a -10an oil return line bulkhead fitting. I have to buy a new drill bit so I wanted to get the right size. Thanks
Old May 3, 2003 | 07:07 AM
Wes V's Avatar
Default Re: What size drill bit would I use for a -10an bulkhead fitting? (Stew Pidasso)
Don't drill the hole (or even buy the drill) until you have the fitting in your hand!
To say that the fitting is a number 10-an just says what size the inside diameter is and that it's for a #10 fitting. It doesn't say what size the outside diameter is and it could vary.
In addition; Maybe I'm unclear what you are doing but it would seem to me that you would want to braze in a "bung" at the oil pan (and then use an adapter to #10). That is unless there is a reason to have an internal pipe to direct the oil.
Wes
Old May 3, 2003 | 07:53 AM
kb58's Avatar
Banned
Use a hole saw or fly cutter. Or, use a small drill and drill many holes around the edge. A large diameter spiral drill will be a disaster in thin material. And, what the other guy said, don't drill until you have the part in hand, OR, have the mechanical drawing of the bulkhead fitting.
Old May 4, 2003 | 10:47 AM
Default Re: What size drill bit would I use for a -10an bulkhead fitting? (kb58)
Thanks guys.
Old May 4, 2003 | 10:50 AM
sgT's Avatar
sgT
do not use a bulkhead fitting for an oil pan.
use either a -10 weld fitting or a 1/2" NPT to -10 fitting instead.
Old May 4, 2003 | 02:49 PM
Default Re: What size drill bit would I use for a -10an bulkhead fitting? (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">do not use a bulkhead fitting for an oil pan.
Any reason why?
Old May 4, 2003 | 09:18 PM
sgT's Avatar
sgT
sticksin too far usually.
D16SohcVtec
Apr 29, 2009 05:57 AM
TwoKSiR
Jun 9, 2008 08:13 AM
TurblowR
Jun 28, 2004 04:13 PM
Trac226
Apr 22, 2002 06:32 PM
