What Drill Bit For 12AN?
Old Apr 28, 2009 | 02:13 PM
D16SohcVtec's Avatar
Default What Drill Bit For 12AN?
Need to tap my oil pan to except a 12AN bulkhead fitting for my oil return. What drill bit is recommended?
Old Apr 28, 2009 | 05:37 PM
miguel329's Avatar
Default Re: What Drill Bit For 12AN?
not sure but if noone help you just take a bit and put fitting on top till you find that matches...
Old Apr 28, 2009 | 06:00 PM
tegman23's Avatar
Ive always just drilled a hole in the pan and got a nut for the other side of the fitting and used silcone to seal it...Worked great just upgraded to a moroso pan
Old Apr 28, 2009 | 08:28 PM
srmofo's Avatar
1an = 1/16 inch,
2an = 2/16 inch,
3an = 3/16inch...etc,etc These are all OD, the ID can vary depending on the hose
12an = 12/16inch = 3/4inch
however you need to measure your fitting sometimes the welded end is different sizes, or use a bulkhead fitting.....
you can use a unibit to dril the hole or drill it small then hog it out with a diegrinder
IMHO if you cant figure out what size drill bit, then you need to take it to someone because noone wants a leaky oil pan.
Old Apr 29, 2009 | 03:11 AM
Brad Campbell's Avatar
Thread size on a -12AN fitting is 1-1/16" @ 12 threads/inch. Tap drill size is somewhere between .972"-.995" depending on thread engagement depth. Through hole should be 1.0625" nominal.
Oh, and -12 is huge for an oil return no?
Old Apr 29, 2009 | 03:28 AM
rota92
Guest
Posts: n/a
Originally Posted by srmofo
1an = 1/16 inch,
2an = 2/16 inch,
The measurement is not the OD always, it's Tubing OD and hose ID. Much like when you refer to piping, or tubing in the plumbing world.
Also, he did say he was using a bulkhead fitting.
OP, so long as you are close enough to the OD of the thread that you get a good snug fit and proper sealing with the teflon washer you'll be fine.
The post above me gives you some good info, in the future just grab some verniers and hit the OD of the threads and you'll know where to start
Old Apr 29, 2009 | 05:57 AM
Thanks for the response guys.
rdeezy78
Nov 2, 2009 06:45 PM
TwoKSiR
Jun 9, 2008 08:13 AM
mahatma
Jul 18, 2005 05:34 PM
TurblowR
Jun 28, 2004 04:13 PM
Stew Pidasso
May 4, 2003 09:18 PM
