Transmissions?
Anyone have some knowledge to gsr trannies. I need to know what all honda trannies will bolt up? mines shot i can get honda trannies from $50-250 but he has no gsr's only gs's ls's and hondas
what that tranny? like how does the gear ratio stand up to the gsr. I am alreadyhaving problems with the gsr being to close i would like to find a taller setup if possible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap »</TD></TR><TR><TD CLASS="quote">See if you can get a B16 tranny (hydro) if you can.
Same as Type R except for the finial drive.</TD></TR></TABLE>
Is this a test of two gearboxes on the same engine? If so, shouldn't the first gear be the same since they both have the same first gear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StinkyTofu »</TD></TR><TR><TD CLASS="quote">
Is this a test of two gearboxes on the same engine? If so, shouldn't the first gear be the same since they both have the same first gear?</TD></TR></TABLE>
Yes they have the same first and second gear, but what skews it is the FD. You have to take that into consideration.
there is this guys that is selling me a GSR tranny he says that is from a 97 or 98 model, but how can I know that is a GSR tranny, is there any code that it should have on?
thanks guys
thanks guys
http://www.bseries.net/html/specs/btrannyspecs.php
go there it will show you all the gear ratios for all b series transmissions.
it also has the codes, as for the gsr tranny (mated with a b18c1, gsr, motor) the code is Y80. you can see this on a small plate right on the edge of the tranny, where the tranny meets the block when mounted. it should say Y80 and then a bunch of numbers.
HTH
HTH
90lsvcrxva
Transmission & Drivetrain
Oct 10, 2008 09:07 PM
integraautox
Mar 28, 2003 06:37 PM
