Transmissions?
Old May 2, 2003 | 09:36 PM
GForceInteg's Avatar
Default Transmissions?
Anyone have some knowledge to gsr trannies. I need to know what all honda trannies will bolt up? mines shot i can get honda trannies from $50-250 but he has no gsr's only gs's ls's and hondas
Old May 2, 2003 | 11:12 PM
KingJeff's Avatar
Default Re: Transmissions? (GForceInteg)
what car do u have again?
Old May 3, 2003 | 02:37 AM
Danger's Avatar
Default Re: Transmissions? (Jeff K.)
ALL B series hydro trannies will bolt up . LS , B16 , ITR , GSR.....
Old May 3, 2003 | 10:56 PM
Default Re: Transmissions? (JonnyDanger)
itr?
what about honda trannies?
oh and 98 GSR
Old May 3, 2003 | 11:32 PM
Henry HA's Avatar
HAnda-Tech Member
itr = integra type r
Old May 3, 2003 | 11:55 PM
GSR Dave2094's Avatar
Default Re: Transmissions? (B18C_DC2)
Any B series tranny wikll bolt up to any B series motor (as said above) cable if it's pre'94 and Hydro for '94_ Teg's.
Good Luck!!
Old May 4, 2003 | 12:26 AM
Dee's Avatar
Dee
Default Re: Transmissions? (GSR Dave2094)
Nice "Road Warrior" Wheels. I can get you a Civic Y21/S21 or an Integra Y80/S80 for about $500 shipped from Japan.
Old May 15, 2003 | 06:34 PM
what that tranny? like how does the gear ratio stand up to the gsr. I am alreadyhaving problems with the gsr being to close i would like to find a taller setup if possible.
Old May 15, 2003 | 07:00 PM
ragejed's Avatar
LS then.
Old May 15, 2003 | 08:25 PM
bocian's Avatar
Default Re: Transmissions? (ragejed)
if thats your car, i say go with an ls tranny, maybe throw in a better fd in there
Old May 15, 2003 | 09:05 PM
Default Re: Transmissions? (bocian)
Ls has taller gears? i thought it was smaller, and whats fd?
Old May 15, 2003 | 09:12 PM
P1mpSlap's Avatar
See if you can get a B16 tranny (hydro) if you can.
Same as Type R except for the finial drive.
Old May 15, 2003 | 09:18 PM
turbospool's Avatar
Default Re: Transmissions? (P1mpSlap)
is there a chart like that with the LS in there too?
Old May 15, 2003 | 09:26 PM
StinkyTofu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">See if you can get a B16 tranny (hydro) if you can.
Same as Type R except for the finial drive.</TD></TR></TABLE>
Is this a test of two gearboxes on the same engine? If so, shouldn't the first gear be the same since they both have the same first gear?
Old May 15, 2003 | 09:43 PM
turbospool's Avatar
Default Re: Transmissions? (StinkyTofu)
first gear is the same, except the type r has a longer redline/power.
sak's Avatar
sak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StinkyTofu &raquo;</TD></TR><TR><TD CLASS="quote">
Is this a test of two gearboxes on the same engine? If so, shouldn't the first gear be the same since they both have the same first gear?</TD></TR></TABLE>
Yes they have the same first and second gear, but what skews it is the FD. You have to take that into consideration.
ok b16 comes on?
Old May 15, 2003 | 09:46 PM
integracion's Avatar
there is this guys that is selling me a GSR tranny he says that is from a 97 or 98 model, but how can I know that is a GSR tranny, is there any code that it should have on?
thanks guys
Old May 15, 2003 | 10:55 PM
HybridEarthquake's Avatar
Default Re: Transmissions? (integracion)
I have a similar question. Just bought a 93 GSR trans from a guy on Honda-tech, How do I know if it really a GSR???
Old May 16, 2003 | 05:36 AM
StinkyTofu's Avatar
Default Re: Transmissions? (sak)
Both the USDM gsr and itr trannies come with a 4.40 final drive. Only the JDM ITR tranny in '98+ are the ones with the 4.7x final drives. It should be the same on the graph...
Old May 16, 2003 | 11:02 AM
bocian's Avatar
http://www.bseries.net/html/specs/btrannyspecs.php
go there it will show you all the gear ratios for all b series transmissions.
it also has the codes, as for the gsr tranny (mated with a b18c1, gsr, motor) the code is Y80. you can see this on a small plate right on the edge of the tranny, where the tranny meets the block when mounted. it should say Y80 and then a bunch of numbers.
HTH
Old May 16, 2003 | 01:43 PM
hey thx alot. thats exactly what i needed
94_Teggy
Jun 23, 2009 01:41 PM
90lsvcrxva
Transmission & Drivetrain
Oct 10, 2008 09:07 PM
zlada14
Jun 25, 2007 04:21 PM
integraautox
Mar 28, 2003 06:37 PM
