Attn: FJO Lambda Meter Users some questions! NEED HELP!
Old May 2, 2003 | 01:12 PM
mamaboy's Avatar
Default Attn: FJO Lambda Meter Users some questions! NEED HELP!
Ok I just talked to Hondata and they told me I couldn't use the FJO Wideband Oxygen Sensor Controller with a Palm Pilot. I just went onto http://www.fjoinc.com and it seems like they have that option. Could anybody give me some insight into how it works and what is necessary for it. Here's the site:
http://www.fjoinc.com/automoti...o2rpm
If anybody has come across my posts....I got my car stolen...but have moved my interested onto my lil' bro's EK D-series.
parts I need for the FJO
1. Wideband Oxygen Sensor Controller (with optional RPM/AUX input)
2. Connectivity (Datalogging) Kit
3. Wideband 02 Sensor
4. PalmOS version 3.5 or greater + Palm Pilot dur
Thanks
Old May 2, 2003 | 01:15 PM
b18bturbo's Avatar
Default Re: Attn: FJO Lambda Meter Users some questions! NEED HELP! (mamaboy)
you need the fjo kit with datalogging we have them here as long as you got the software installed you should be fine.
Old May 2, 2003 | 01:17 PM
b18bturbo's Avatar
Default Re: Attn: FJO Lambda Meter Users some questions! NEED HELP! (b18bturbo)
This Wideband O2 Sensor Kit is intended for use with a stand-alone ECU (i.e. AEM, Motec, Haltech, etc). There is no display included. It comes with the necessary connection to display it on a laptop or PDA. You can add a plug-and-play display unit at any time in the future.
This kit also includes the "Connectivity Kit" for complete data logging capabilities. The Connectivity Kit includes RPM and AUX direct connect input cables, serial cable, PDA adapter, PC and PDA data logging and analysis software (on CD ROM).
This kit includes the following parts: CWC0002 wideband oxygen sensor controller - SO20001 wideband oxygen sensor - MSW0101 connectivity kit - MWI0001 installation manual - IWC0002 installation kit - HSB0001 O2 sensor bung.
Your Price $806.00
Old May 2, 2003 | 01:58 PM
mamaboy's Avatar
Isn't the unit itself cost like $560 or somewhere around there.....so the data connect kit costs close to $300...is this true? Wow....I just wanted to use it display in realtime...but...wait it comes with an 02 sensor...that's not bad.....and where can you get the software for the PDA....??? I'm absolutly interested....more information would be great....
Old May 6, 2003 | 09:48 AM
psileepR's Avatar
New User
sup johnny glad to see u still have the fire for hondas after what happened.
gl with your bros project car.
what other options are there out there for wb02's?
FJO, techedge??
With the current supply of o2 sensors that tech edge uses, wb02's are becoming extremely expensive or sometimes impossible to complete. is fjo a better alternative?
Txdragon
Engine Management and Tuning
Feb 27, 2017 03:03 AM
EGRhatch
May 15, 2011 11:29 AM
Asahi
Jan 1, 2005 04:06 PM
philo
Apr 6, 2002 09:44 AM
