oil pressure gauge
Old May 2, 2003 | 08:26 AM
Max_lude's Avatar
Default oil pressure gauge
where do i put the oil sender unit on a h22?
Old May 2, 2003 | 08:41 AM
Greyout's Avatar
Default Re: oil pressure gauge (Max_lude)
A common way to do it is to put a brass 'T' fitting into the back of the block where the stock sensor is, and then put the new sending unit on one side and the new one on the other.
Old May 2, 2003 | 10:23 AM
Max_lude's Avatar
Default Re: oil pressure gauge (JDM LUDE)
can i replace de stock sensor by the sending unit i got with the gauge?
Old May 2, 2003 | 10:29 AM
4bidden's Avatar
Speaking of oil pressure gauges. Mine is f*cked up...its pegged at like 140psi even when the car is off. WTF is up with that.
Old May 2, 2003 | 10:38 AM
Greyout's Avatar
Default Re: oil pressure gauge (4bidden)
that means that there is a short in the signal wire, which is grounding it out. Or the gauge itself is fux0red, but more likely its your wiring.
Also, I don't think the factory warning light is compatable with the aftermarket sending unit, but I have no idea.
Old May 2, 2003 | 11:13 AM
Max_lude's Avatar
what i meant was that if i can put the sending unit where the stock sensor is? and get rid of the stock sensor cause if i have a oil pressure gauge i wont need the stock sensor?
this that make sense?
Old May 2, 2003 | 10:06 PM
Max_lude's Avatar
Old May 2, 2003 | 10:56 PM
TimeRacer's Avatar
You can do it that way. Most people don't due to the fact that your oil light may (I don't know for sure) throw a CEL that puts you into limp mode and I don't think that it'll allow VTEC. Putting a T on it is a bad idea due to the weight of the T fitting.
Old May 3, 2003 | 04:06 AM
Max_lude's Avatar
Default Re: oil pressure gauge (TimeRacer)
what would you suggest then?
Old May 3, 2003 | 10:49 AM
BoostedH23a1's Avatar
i woiuld T it man.. if u dont and u dont pay attention u could somehow run outta oil and not know it.. not likely but possible..
EG-SIXV-TEC
Mar 6, 2017 08:48 AM
shadhman
Jan 29, 2009 05:55 PM
Powelly
Apr 11, 2008 12:59 AM
2khb
Apr 22, 2005 03:55 AM
Prelude MIke
Jun 9, 2004 11:58 AM
