b16 sir 2 cams
Old May 1, 2003 | 08:08 PM
riceball777's Avatar
Default b16 sir 2 cams
i'm about to get some b16(170hp) sir 2 cams for my first gen b16
how can i tell if i'm really geting the right cams. is there any thing on the cam that can identify it as being the second gen b16 cams
how much more power can i expect? how much more hp?
i heard that the only reason the second gen b16 has 10 more hp is from the cams.
is this true? and if it is can i expect 10 more hp?
Old May 1, 2003 | 08:39 PM
Default Re: b16 sir 2 cams (riceball777)
does anyone know
can anyone help?
Old May 1, 2003 | 08:58 PM
CLICC916's Avatar
hey man, some advice--do a search on it first...but here's pics. look at the rings/grooves on the distributor side of the camshafts...they should match whichever b-series vtec cam you want. btw, itr and ctr exhaust cams are the same...also, i think the 98-99 itr is different from the 00+ itr
Old May 1, 2003 | 09:06 PM
usdm_ED7's Avatar
Default Re: b16 sir 2 cams (CLICC916)
honestly i would save up some money and get some other cams. the 2nd gen you are thinkin about will not give you an extra 10 hp. the cams are a lil more aggressive then the 1st gen but the 2nd gen also has a slighly higher compression. hope that helps. correct me if im wrong
Old May 1, 2003 | 09:09 PM
CLICC916's Avatar
Default Re: b16 sir 2 cams (usdm_ED7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdm_ED7 &raquo;</TD></TR><TR><TD CLASS="quote">honestly i would save up some money and get some other cams. the 2nd gen you are thinkin about will not give you an extra 10 hp. the cams are a lil more aggressive then the 1st gen but the 2nd gen also has a slighly higher compression. hope that helps. correct me if im wrong </TD></TR></TABLE>
i agree, get the ctr or skunk2 stage 1 or two cams instead if you want to upgrade
Old May 1, 2003 | 09:30 PM
i'm geting these cams cuz i'm a broke college student and i'm geting them for only 40 bucks so i think its a preatty good deal
Old May 1, 2003 | 09:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CLICC916 &raquo;</TD></TR><TR><TD CLASS="quote">hey man, some advice--do a search on it first...but here's pics. look at the rings/grooves on the distributor side of the camshafts...they should match whichever b-series vtec cam you want. btw, itr and ctr exhaust cams are the same...also, i think the 98-99 itr is different from the 00+ itr
thx man you were a lot of help
Old May 1, 2003 | 10:14 PM
CLICC916's Avatar
np, i asked the same thing before i bought my ctr cams
Old May 1, 2003 | 10:55 PM
thaiphob's Avatar
Nikon!!!
why dont you get gsr cams insted?
Old May 1, 2003 | 11:46 PM
Default Re: b16 sir 2 cams (thaiphob)
are gsr cams better than 2nd gen b16(170hp) cams
Old May 2, 2003 | 06:03 AM
slowpokesi's Avatar
the 2nd gen doesnt have 10 more hp than the first gen because of the cams,
there is minimum diffrence in the cams,
the reason the 2nd gen b16a makes more power, is the compression is higher.
Old May 2, 2003 | 08:21 AM
Davep's Avatar
Yea, not worth swaping IMO... keep you 40$ and find 260$ more and get some ITR.
The combination of the cams, .2 more CR and the ecu give you the extra HP of the second gen.
BTW, "SIR 2" doesn't mean its a 2nd gen B16A.
Old May 2, 2003 | 08:47 AM
Timmayeg's Avatar
New User
Default Re: b16 sir 2 cams (Davep)
still the 92+ cams are better than 88-91's. and the 92+b16 cams are same specs as usdm gsr
Old May 2, 2003 | 08:56 AM
usdm_ED7's Avatar
Default Re: b16 sir 2 cams (slowpokesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">the 2nd gen doesnt have 10 more hp than the first gen because of the cams,
the reason the 2nd gen b16a makes more power, is the compression is higher.</TD></TR></TABLE>
lol thats what i said
Old May 2, 2003 | 10:16 AM
Timmayeg's Avatar
New User
so .2 compression is 10 HP? its a combonation of better cams and a tid bit more compression
Old May 2, 2003 | 10:33 AM
Malgerus's Avatar
Default Re: b16 sir 2 cams (Timmay)
Not to mention a bigger throttle body.
Old May 2, 2003 | 10:54 AM
usdm_ED7's Avatar
Default Re: b16 sir 2 cams (Mr. S)
dont spend 40 bucks on those...i would just save it up for something else, and i highly doubt you will 'feel' a power difference.
rioninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">Not to mention a bigger throttle body.</TD></TR></TABLE>
Im glad somebody pointed that out. The 2nd gen TBs are massive in comparrison to the 1st gen.
Old May 2, 2003 | 11:06 AM
Charlie Moua's Avatar
Default Re: b16 sir 2 cams (rioninja)
Well you will not gain 10hp from just the cams. I'm thinking about 4-5whp.
for $40bux sure why not. You should only get them if you know how to properly install them yourself. If you have to pay for installtion... it's not worth it.
good luck
Old May 2, 2003 | 12:46 PM
Timmayeg's Avatar
New User
Default Re: b16 sir 2 cams (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">Well you will not gain 10hp from just the cams. I'm thinking about 4-5whp.
good luck </TD></TR></TABLE>
thats how i se it
Old May 2, 2003 | 02:43 PM
Timmayeg's Avatar
New User
so does anyone know the specs on b17 cams? are they the same as gsr's or 92+jdm b16's?
Old May 2, 2003 | 06:15 PM
CRVRX's Avatar
I have a pair of 2001 ITR cams brand new in the box. I'll sell them for $450 shipped.
1slowcrx
Apr 14, 2004 10:33 AM
riceball777
May 2, 2003 09:12 AM
riceball777
May 2, 2003 05:07 AM
SuperCivic
Jul 23, 2002 02:48 PM
SuperCivic
19
Jun 28, 2002 07:09 PM
