JDM ITR fog light switch diagram?
does anyone know how to wire the fog light switch for the jdm hid head lights
i have the switch has 5 wires.
does anyone have the diagram to wire the foglight switch?
i think the wiring for the light into the fuse box in that picture is incorrect. my fusebox itself doesnt look like that...
btw, does anyone have the switch plug diagram? (which is constant 12v, switched 12v, ground...etc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** »</TD></TR><TR><TD CLASS="quote">i think the wiring for the light into the fuse box in that picture is incorrect. my fusebox itself doesnt look like that...
btw, does anyone have the switch plug diagram? (which is constant 12v, switched 12v, ground...etc)</TD></TR></TABLE>
was in the link that the d8168055 posted
i already have the plug so i didnt have to get it from my cruise control but the red/yellow stripe wire on mine is actually red/green stripe wire
does anyone have the right pics were the wires go?
Has anyone that has the raybrig fogs on their car wired the jdm switch to them? I got my stock switch hooked up to turn on and off my jdm fogs, but I want to use the jdm switch. Anyone know the process?
You mean your Fusebox isn't Red with Blue fuses??
It is the correct pinouts for the 3 power wires. Look above your fuses and next to the plugs already plugged in...
And if your doing this install and you don't have a Test Light or Voltmeter to check connections then you shouldn't be installing something of an electrical nature in a car.
I have th eUKDM switch in my car and it's wired to my Piaas. I just took the piaa switch apart and while i was using the multimeter managed to fry that switch so i just desoldered the wires from it and ran those dierectly to the UKDM switch. Only had to run one other wire to the switch for the amber instrument light to work. Only real problem I had was that in the UK they must have some control box for the lights and the switch was not latching. I ended up ordering a latching switch from e-switch and desoldered the old one and soldered in the new one....like it cam from the factory that way. Works great and looks much better.
If you still theed the pinout of the wires let me know, UK and JEM are the same pinout.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike M »</TD></TR><TR><TD CLASS="quote">
And if your doing this install and you don't have a Test Light or Voltmeter to check connections then you shouldn't be installing something of an electrical nature in a car.</TD></TR></TABLE>
voltmeter i have. what i dont have is the exact fusebox as pictured. mine is actually lacking an extra connector on top.
What this implies for me is uncertain, as I forgot what the verdict was the last time i tried to wire it together.
-Tom
-Tom
uh oh, those things are a fog light switch?!? I push on mine and the horn goes off.
y
shi - who was told by a honda technician that the pic on the button is a horn w/ soundwaves coming out LOL
y
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d8168055 »</TD></TR><TR><TD CLASS="quote">does anyone know if the JDM fog switch is the same as the prelude switch?</TD></TR></TABLE>
