Help!!! I'm about to buy ITR.
Old May 1, 2003 | 02:47 PM
dp's Avatar
dp
Default Help!!! I'm about to buy ITR.
PY ITR #01-1301 with 9242 miles.
Exterior:
1) no bodywork repairs as far as I can tell all body panels have original VIN# stickers on them, no dings or dents.
2) some scratches in front lip, one "medium" scratch on rear bumper
3) slight discoloration on rearview mirrors and front fascia(I've seen several integras like, is this normal?)
4) weatherstripping around windows is "rough"
Interior:
1) no blemishes or spots in seats or upholstery
2) no cracks on dash or door panels, some minor marks on cargo panels
3) fairly clean but the owner drove a lot with windows down so there is dust in all little joints and crevices etc. (probable signs of track use)
Engine:
1) everything is stock!!!!!
2) I checked ALL the bolts and nuts to see if they have been messed with and no signs of "wrenching" is evident. The FPR still have that little paint on the bolts so does the TB and the IM. The nuts on the valve cover don't show any marks either.
There is one thing that worries me. The bolts that mate the tranny to the engine do show marks around them (weird 'cause the motor mounts don't) How can I know if the LSD or even the true ITR gearing is inside?
Old May 1, 2003 | 03:17 PM
dp's Avatar
dp
Default Re: Help!!! I'm about to buy ITR. (dp)
C'mon help me! I will test drive the car this weekend. I'll check the stamps on the head to see if its a real ITR head and check the VIN # on the tranny to see if it matches. I'm not crazy dude some people here really slick.
Old May 1, 2003 | 03:31 PM
Philly_NBP_R's Avatar
Run the vin on Carfax and make sure it was never wrecked / stolen.
Do a compression test if your'e worried about the motor- with only 9,000 miles that shouldn't be an issue.
Dust in the crevasses is not a sign of track use - it's a sign of car use
Check that all body panels are aligned properly.
Check for all records, manuals. etc.
Are the Original Re-010 tires still on the car, in good shape? (if so - it was DEFINATELY not a track car - they wear out very quickly).
Do a search! This topic has been covered 100 times already...
good luck
Oh - if your'e worried about the LSD - jack up the front of the car, and rotate one of the drive wheels - the other should rotate in the opposite direction - this means the LSD is present and operating correctly...
Old May 1, 2003 | 04:02 PM
baonest1's Avatar
Default Re: Help!!! I'm about to buy ITR. (Philly_NBP_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">
Oh - if your'e worried about the LSD - jack up the front of the car, and rotate one of the drive wheels - the other should rotate in the opposite direction - this means the LSD is present and operating correctly...</TD></TR></TABLE>
true that
Old May 1, 2003 | 05:22 PM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">Oh - if your'e worried about the LSD - jack up the front of the car, and rotate one of the drive wheels - the other should rotate in the opposite direction - this means the LSD is present and operating correctly...</TD></TR></TABLE>
NO!!! This is NOT true. That only proves that the diff is working correctly. You would get the same results with an open diff (no LSD).
To see if the LSD is there/working, just gas it around a corner in first, you should feel it at work.
Old May 1, 2003 | 05:26 PM
Cosworth's Avatar
Default Re: Help!!! I'm about to buy ITR. (Dr Pooface)
ITR gearing: At least for 5th gear -&gt; 77mph turns 4,300 rpm on the stock tach.
Old May 1, 2003 | 06:59 PM
TypeR 599's Avatar
Default Re: Help!!! I'm about to buy ITR. (Cosworth)
the car sounds fine, but carfax it anyways.
Old May 1, 2003 | 07:13 PM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dp &raquo;</TD></TR><TR><TD CLASS="quote">PY ITR #01-1301 with 9242 miles.
Exterior:
Interior:
Engine:
There is one thing that worries me. The bolts that mate the tranny to the engine do show marks around them (weird 'cause the motor mounts don't) How can I know if the LSD or even the true ITR gearing is inside? </TD></TR></TABLE>
dude your hard core, you pay MUCH attention to detail.. i ride all the time with windows down.. its hott in louisiana, hehe a/c sux to
Old May 2, 2003 | 02:30 PM
dp's Avatar
dp
Default Re: Help!!! I'm about to buy ITR. (Jordo)
Jordo: This is the only way to be sure everything that makes an ITR is in there. Cams could be change for GSR or SI cams or the TB even the tranny like I said. Also by inspecting the bolts and nuts you can learn everything that have been made to the car from repairs to mods. It helps diagnose future problems and saves you from buying a lemon.
Philly_NBP_R: No the original tires are gone. The wheels are in very good shape.
TYPER 599: I think Carfax will not work for cars in Puerto Rico
Old May 2, 2003 | 04:21 PM
t o m's Avatar
now this is what researching a car before buying is all about props to u for puttin in the effort
Old May 2, 2003 | 06:41 PM
dp's Avatar
dp
Default Re: Help!!! I'm about to buy ITR. (TOManegi)
TOManegi: Thanks!!!
Cosworth: Thanks, I'll try that to check if the geraring is right. How about 1st and 2nd gears?
Back to the question, how to tell is lsd is installed
Old May 2, 2003 | 06:43 PM
Dr Pooface's Avatar
Either you can rip the axels out and look, or just feel for it during your test drive.
etank82
Jul 11, 2009 02:52 PM
boosted94cx
Aug 20, 2006 06:37 PM
idriveadelsol7
Welding / Fabrication
May 11, 2005 08:35 PM
integra81
Feb 11, 2002 12:47 PM
