greddy turbo kit owners- size of union piece going to oil feed line?!!
i cannot find this exact size... i need the union piece that connects the oil feed line to the NPT T that comnes with the kit.
the 1/8 NPT union ALMOST threads up, but I believe its another size
here is a picture
here is a picture
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poxu »</TD></TR><TR><TD CLASS="quote">1/8 bspt</TD></TR></TABLE>
I'm hoping i can find that at a hardware store...
you won't. trust me, I have enough contact when it comes to bolts, fittings and etc.. and none will have a BSPT fitting, because there are no application for it, but automotive, in specific import...
stan
stan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote">you won't. trust me, I have enough contact when it comes to bolts, fittings and etc.. and none will have a BSPT fitting, because there are no application for it, but automotive, in specific import...
stan
indeed i believe you're right. I've went to every car and hardware store in my area and no luck. sad thing is flamenco-t... that all i need is that one single union in order to finish my kit.. and (nothing personal but) i'd hate to spend 55 bucks on your kit for one stinking little bolt!!
stan
I got my BSPT male to NPT female adapters from Stan
I got a BSPT male to NPT male union from mcmaster(www.mcmaster.com), and I think they might carry the male to female adapters as well.
They have them in alu, steel, brass, etc. Just go in under pipe and fittings, then select the material you want, then select nipples, then there should be an option for NPT>BSPT.
seeeya04
Dec 12, 2005 05:08 PM
