o2 problem again (b16a)
Old May 1, 2003 | 08:42 AM
silverCRXTC's Avatar
Default o2 problem again (b16a)
i changed both o2 sensors and reset the ecu, and still i get a cel 1 when i rompt on the car,
(I got a a b16a), did i reset the ecu right? i pulled out the ecu fuse and still i have a cel, any idea?
thanks
Old May 1, 2003 | 09:05 AM
slowpokesi's Avatar
Default Re: o2 problem again (silverCRXTC)
resetting the ecu
- warm up car
- turn car off
- pop hood
- pull hazard fuse
- pull ecu fuse
-wait 10 minutes
- plug fuses back in
- start car
- dont touch the gas pedal for 10 minutes
which header are you using, are the o2 sensors in the right location, you might need to switch the pins in ur wiring.
scoob8000
11
May 30, 2010 02:32 PM
SpeedingHatch
Jun 25, 2006 12:47 PM
accordianex
43
Mar 19, 2006 10:25 AM
roc
May 7, 2003 06:53 PM
