Strange sound from my BOV - need some input...
Old May 1, 2003 | 08:33 AM
Crimson490's Avatar
Default Strange sound from my BOV - need some input...
BOV sounded nice from 0-6psi. I hooked up my conquest intercooler, and now the BOV sounds wierd - like it echos or vibrates once or twice before completely blowing off - like it skips a beat. The reverb doesn't happen at 5-6psi, but down lower.
-I've adjusted the BOV spring all the way in, and it's worse - happening no matter what boost level.
-I've let the spring all the way out, and it does it at 0-4 or so psi.
-I'm running a (slightly modified) Greddy sohc kit (with custom FMIC), TurboXS high perf. MBC, and Blitz dual drive BOV.
Any thoughts?
here's a pic of my intercooler setup:
Old May 1, 2003 | 09:29 AM
madman604's Avatar
Default Re: Strange sound from my BOV - need some input... (Crimson490)
vaccuum leak, check hosing
Old May 1, 2003 | 09:46 AM
*Boostwerks*'s Avatar
I'm not sure if this contributes to it, but That sure is a lot of charge piping .
Old May 1, 2003 | 10:10 AM
intekragsr's Avatar
Default Re: Strange sound from my BOV - need some input... (Bryson)
The rattling can be from the intercooler if its not bolted down snug. Mine actually did that because when it blew off, it caused a little surge so the intercooler jiggled.
And yes, check for vacume or boost leaks. Try hooking the bov to an independent source.
Old May 1, 2003 | 10:26 AM
Crimson490's Avatar
Default Re: Strange sound from my BOV - need some input... (intekragsr)
I think it's pretty snug - riveted to frame, bolted to brackets with lock nuts. But I will def. check the hoses.
Old May 1, 2003 | 07:36 PM
Turbo88Lude's Avatar
same amount of piping as any stock evo 1-4 , wouldnt say that has anything to do with it
Mr HYDE
Aug 30, 2006 05:09 PM
vtec.dc2
Aug 23, 2006 12:58 PM
SiRex91
May 7, 2004 12:13 PM
Pritos
Jan 12, 2002 03:12 PM
