energy suspension bushing inserts
Old May 1, 2003 | 08:30 AM
black_sh's Avatar
Default energy suspension bushing inserts
does anyone know where i could find the urethane energy suspension bushing inserts for a 97-01 prelude? i have to get rid of the front motor mount for my turbo to clear and i want something stronger to support it. does anyone know of a place that makes it for my year or anything else that i could do? any help would greatly be appreciated
Old May 1, 2003 | 10:50 AM
Casual Gcode1's Avatar
Default Re: energy suspension bushing inserts (black_sh)
dont think they make one
Old May 1, 2003 | 01:10 PM
Greyout's Avatar
Default Re: energy suspension bushing inserts (Casual Gcode1)
you want to use only 3 motor mounts?
and yes, it appears that they only make the entire kit for 4th gens. The motor mount inserts however, fit both.
Old May 1, 2003 | 02:23 PM
black_sh's Avatar
Default Re: energy suspension bushing inserts (JDM LUDE)
my turbo will not clear the motor mount. are you sure that the 92-96 fits the 01?
Old May 1, 2003 | 02:46 PM
Greyout's Avatar
I can't imagine why not...
but as far as removing the mount entirely, I think thats a very very bad idea and you should look for some other way to squeeze the turbo in there.
Old May 1, 2003 | 03:27 PM
black_sh's Avatar
it's the t3 60-1 .82 ar housing. it won't clear the motor mount
Old May 1, 2003 | 03:54 PM
dcb0821's Avatar
I have a friend running a 5th gen with no front motor mount and no inserts on the other mounts, he is still in the tuning stages, but from what he can tell everything seems to be ok as is, time will tell....
Old May 2, 2003 | 07:57 AM
black_sh's Avatar
Default Re: energy suspension bushing inserts (slowlude)
i know of someone doing the same thing too...just kinda worried that something might happen.
Old May 2, 2003 | 08:15 AM
94turbolude's Avatar
i just built the front mount for mine cuz i ran into the same problem as you did (no clearence) i used a energy suspention chevy 350 engine mount and some time with the good old mig welder
Blake
Old May 2, 2003 | 08:24 AM
black_sh's Avatar
Default Re: energy suspension bushing inserts (94turbolude)
so...you still basically have a front motor mount? do you think if i ran with only the 2 side and back motor mount it would be ok???
Old May 2, 2003 | 09:47 AM
R@mon's Avatar
check this out. i asked them same thing....
i think it could be done you just have to make the rear mount completely solid . inserts wont be enough.....
https://honda-tech.com/zerothread?id=452261
Old May 2, 2003 | 10:12 AM
black_sh's Avatar
Default Re: energy suspension bushing inserts (93h22a4)
where would i get a completely solid mount from?
airmaxbri
Oct 8, 2010 11:27 AM
ctr status
May 8, 2006 11:24 AM
m0t0rhead
Dec 28, 2002 01:31 PM
p10hlm
Nov 30, 2002 02:05 PM
