bad fuel pump?????????????
Old Apr 30, 2003 | 10:02 PM
alky350's Avatar
Default bad fuel pump????????????? Please help, its my daily driver!
My 1989 honda civic hb (DPI) starts for about 3-4 seconds and then it dies....i replaced the fuel filter today and i can hear the fuel pump working. i resoldered the main relay. i noticed BEFORE when the tank was half full the car would not accelerate....almost like if it was starving. i would then fill it back up and it would work fine. but now the car doesnt stay on for more than 3-4 seconds and then dies..UNLESS i throttle it back and fourth to keep it running eventually it dies. please help....its my daily driver
Old Apr 30, 2003 | 10:56 PM
alky350's Avatar
Default Re: bad fuel pump????????????? Please help, its my daily driver! (alky350)
bump
Old Apr 30, 2003 | 10:58 PM
SIRX's Avatar
are you throwing any codes? what were the circumstances leading up to this? has it been running bad for a while?
Old May 1, 2003 | 04:49 AM
Flexmyrex's Avatar
Default Re: bad fuel pump????????????? Please help, its my daily driver! (SIRX)
do a fuel pressure test to find out for sure, it should be reading 36-41 psi.
if it reads higher than spec psi its your fuel pressure regulator, lower than spec its your fuel pump
Old May 1, 2003 | 05:59 AM
alky350's Avatar
Default Re: bad fuel pump????????????? Please help, its my daily driver! (flexmyREX)
Thanks, ill check the fuel pump pressure....it has been running bad for awhile too!
Old May 1, 2003 | 06:00 AM
IamVtec's Avatar
try adjusting the screw on the Throttle body to the left, turn it about 2 full turns and try to start it again.
Mines was doing the samething and prob was fixed.
ejfromwestbay
Aug 18, 2010 05:44 PM
HmgLauj69
Dec 23, 2005 05:48 PM
dEtSoOb
Jul 12, 2005 06:08 PM
Red D Dragon
Apr 3, 2004 06:53 PM
shermanyang
Mar 18, 2004 10:47 PM
