Can Someone help my friend and I out with wiring v-tec?
Old Apr 30, 2003 | 07:20 PM
H2296precord's Avatar
Default Can Someone help my friend and I out with wiring v-tec?
My friend and I are working on his 89 crx si. However it has a 93 sohc v-tec si engine in it, but v-tec isn't hooked up. We were told that it's possible to wire v-tec to a tach, and would be able to set v-tec off whenever. How would we go about wiring v-tec to the tach? Like we would like to know all the details and everything. HHHHHHEEEEEEEELLLLLLLLPPPPPPPPP!?!?!?!?!?!?!?!?!?! ?!?!
Old Apr 30, 2003 | 10:14 PM
SIRX's Avatar
Default Re: Can Someone help my friend and I out with wiring v-tec? (H2296precord)
http://www.thezcr.com/html/odbiconversion.php
this might help or type in "wiring vtec into the search also search arcived topics there's like 114 topics
Old May 1, 2003 | 04:38 AM
zCivic's Avatar
Default Re: Can Someone help my friend and I out with wiring v-tec? (SIRX)
Your gonna need a Tach with a Shiftlite, not any old tach will work. Can also use a RPM activated switch like MSD, Autometer, etc. Can also go with a toggle switch in a worse case (dont suggest this one for any long term installs)
Old May 1, 2003 | 06:26 AM
88_SC_CRX_Si's Avatar
New User
Here are some different ways of going about it...
http://geocities.com/chipman_13/mini-me-parts.html
Old May 1, 2003 | 06:46 AM
USDM 4G VTEC's Avatar
well theres differents ways
u can use a shiflight.... switch, vtec controler
u can use a MSD RPOM activated switch, Zdyne ecu , etc
i currently have a MSD RPM activated switch with all instructions, relay, and 4200,4400,4600,4800, pills , shipped to ya for $75
Old May 1, 2003 | 02:50 PM
ok, we have a tach with a shift light already. wut else do we need? wut type wiring? where does the wiring go? how much wiring do we need? we really need help, and plus not trying to be funny, but i'm a bit slow so your gonna have to really explain it. i thank you guys so much, i'm a bit new on the import's so i'm tryin' my best.
sileighty_911
Sep 13, 2007 09:53 PM
B16tyler422
May 19, 2007 10:59 AM
master honda tech
Aug 19, 2004 07:17 AM
Mr. Thunderlips
20
Jun 8, 2003 01:21 AM
CimorelliCRX
Mar 11, 2003 12:22 PM
