F2 Overheating..help, help!!!
hey i got a 93 F2 CBR, that overheats really easily.. from work to school, which is about 2 miles, it starts to get pretty close to the red.. i checked my coolant resevoir and it seems fine.. any suggestions to what the problem or solution may be would be greatly appreciated-thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbr600jefF2 »</TD></TR><TR><TD CLASS="quote">Check for water leaks and also check that you don't have a faulty radiator fan switch.</TD></TR></TABLE>
Yeah. Actually, flush your coolant system and check the fan switch, the temp sensor, and the thermostat (if it has one, I don't have an CBR manual).
If you check your service manual, it should have a section on how to do this, which is generally relativly easy (takes a multimeter and a stove with a pot of water)
hotcivicsi
11
Apr 9, 2009 06:19 PM
dcdcdc
May 3, 2008 12:08 PM
