180 whp possible with Skunk2 Stage1 with NO tuning?
Old Apr 30, 2003 | 06:14 PM
red civic standard's Avatar
Default 180 whp possible with Skunk2 Stage1 with NO tuning?
2000 JDM ITR motor (11.1 CR)
Skunk2 Stage 1 cams
AEM CAI for 99-00 Si
Comptech 4-2-1
Custom mandrel 2.5 inch exhaust
Clutchmaster flywheel
OBD1 with Kenji chipped p28
No power steering, no a/c
Is 180 whp possible with no tuning?
How much power do you think can be gained with the use of Hondata and cam gear tuning from a <U>good</U> tuner?
Old Apr 30, 2003 | 06:21 PM
rainmanEK's Avatar
big strong guy
Default Re: 180 whp possible with Skunk2 Stage1 with NO tuning? (red civic standard)
Yes Very possible
I laid down 190 on first pull un-tuned (0,0)
Get a chiped ECU (obd1) and VAFC and with good tuned 200whp is within reach!
Eric
B2FiNiTY's Avatar
Power is relative to the dyno.
But more than likely you can.
Old Apr 30, 2003 | 07:24 PM
SurferX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard &raquo;</TD></TR><TR><TD CLASS="quote">How much power do you think can be gained with the use of Hondata and cam gear tuning from a <U>good</U> tuner?</TD></TR></TABLE>
Alot. I gained over 20whp in the midrange and almost 10whp at peak after tuning, and that was on stock cams with a VAFC and cam gears. Just tune it man, it's so worth it.
Old Apr 30, 2003 | 08:05 PM
AcuraR-Type's Avatar
nice
Old May 1, 2003 | 04:43 AM
Default Re: (AcuraR-Type)
I already have a chipped p28 and untuned cam gears (0,0)
Would hondata be overkill for my setup? Should I just get a VAFC?
Old May 1, 2003 | 05:21 AM
b19coupe's Avatar
Default Re: (red civic standard)
Hondata is never overkill in my opinion. A stock motor would benefit from the fine tuning of air/fuel and ignition timing maps offered by Hondata. All you need is a skilled tuner.
Old May 1, 2003 | 05:36 AM
MPH's Avatar
MPH
New User
Doubt it. When I dropped mine in I made 173whp untuned.
I barely made 196 with an hondata. I made 200 with a vafc. The Vafc I tuned myself. Cam gear tuning is where the most power is going to come from. Especially the intake cam.
Old May 1, 2003 | 05:43 AM
Willard's Avatar
Default Re: 180 whp possible with Skunk2 Stage1 with NO tuning? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Power is relative to the dyno. </TD></TR></TABLE>
Will
-who has 181whp with stock camz.
Old May 1, 2003 | 06:21 AM
Chris N's Avatar
Default Re: 180 whp possible with Skunk2 Stage1 with NO tuning? (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Power is relative to the dyno</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">
Will
-who has 181whp with stock camz.</TD></TR></TABLE>
Yea, I got 175whp and have since added the mugen intake and toda header. I'd hope I'm also at 180 on stock cams.
But you can get ALOT more midrange/topend after you tune them cams...
Old May 1, 2003 | 09:40 AM
98TypeR's Avatar
Default Re: 180 whp possible with Skunk2 Stage1 with NO tuning? (Chris N)
Why would you ever want to leave your car untuned. This is so bad for your car. You could potentially be running very lean or very rich. Maybe even get some detonation. Tune the car man. If not to make power get it running at good fuel ratios.
Old May 1, 2003 | 09:54 AM
IN VTEC's Avatar
On a similar '98 GS-R, we were just under 180whp baseline and ended up with 184whp with lots more midrange after an hour of tuning, and we've still gotta get his car back there to play with the cam timing and fuel pressure. Stock 10.0:1 CR.
Details are in the Integra forum under my SN if you wanna see the full-out.
Old May 1, 2003 | 10:10 AM
lakerschamp2000's Avatar
Since your motor is 2000 JDM ITR motor (11.1 CR)
Do not use Skunk2 Stage 1 cams, use stock JDM ITR cams
Do not use AEM CAI for 99-00 Si (2.75" diameter), use AEM ITR CAI 3" diameter
Do not use Comptech 4-2-1, instead used stock JDM header 4-1
Must get fuel adjustable and among other things that you listed.
should pump out at least 180 or over 190 after tuning.
Old May 1, 2003 | 10:16 AM
OBDI JEDI's Avatar
Default Re: 180 whp possible with Skunk2 Stage1 with NO tuning? (lakerschamp2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lakerschamp2000 &raquo;</TD></TR><TR><TD CLASS="quote">Since your motor is 2000 JDM ITR motor (11.1 CR)
why wouldnt he use the Skunk Stage 1's?
Old May 1, 2003 | 10:24 AM
uNF$@#!'s Avatar
Default Re: 180 whp possible with Skunk2 Stage1 with NO tuning? (OBDI JEDI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBDI JEDI &raquo;</TD></TR><TR><TD CLASS="quote">
why wouldnt he use the Skunk Stage 1's?</TD></TR></TABLE>
because JDM is GOD.
Old May 1, 2003 | 10:40 AM
I thought a $100 upgrade to Skunk 2 cams was a good deal.
AEM ITR CAI will not fit in an ef.
JDM 4-1 will not fit in an ef. (also see Great Header Test)
I was wondering what type of adjustable fuel was best (hondata or VAFC). That is why I asked.
Old May 1, 2003 | 10:42 AM
WiggiE's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lakerschamp2000 &raquo;</TD></TR><TR><TD CLASS="quote">Do not use Skunk2 Stage 1 cams, use stock JDM ITR cams</TD></TR></TABLE>
That's like telling someone who wants Jun 3's, to just get Jun 1's.
truazn4lyfe
Nov 14, 2007 09:06 AM
1sikhatch
Nov 16, 2006 01:15 PM
tomlinson619
May 18, 2006 05:02 PM
veilsides2000
Jul 9, 2005 08:05 PM
jonnybravo
Jan 26, 2003 09:55 PM
