tuning???
Old Jul 8, 2005 | 10:15 PM
veilsides2000's Avatar
Default tuning???
i've been thinking about purchasing some skunk2 stage 2 camshafts and want to know that, can i jsut put them on and expect gains??? or do i have to get it tuned?? and how would i go about tuning them do i need to buy a stand alone???? i'm confused here.
Old Jul 8, 2005 | 10:42 PM
Default Re: tuning??? (veilsides2000)
this is going on a gs-r b18c-1
Old Jul 8, 2005 | 11:03 PM
rdblckSV650S's Avatar
tuning would be recommended, or you're probably not going to see much. Stage 2s might even be a little much on a stock compression GSR. You'd be overcamming your motor. A set of cam gears would be recommended, and at least a piggy back fuel computer like a Apexi S-AFC. But some hondata would be awesome, and the gains you saw from the tuning alone would feel good. To tune it you would need to go to a dyno and have them tune it for you.
All of this information can be found with a simple search. Just look around.
Old Jul 9, 2005 | 11:07 AM
Default Re: tuning??? (slvrblckf4i)
okay so would skunk2 stage 2 cams, with the valvetrain, CTR pistons, header, exhaust, cam gears, SAFC be a good setup??? and can i tune it with a p28 that has a skunk2 program?? or do i have to get hondata or uberdata??? and i tried searching but just skunk2 cams, but more skunk2 vs......
Old Jul 9, 2005 | 01:01 PM
mtber's Avatar
I do not recommend running the safc...
Look into uberdata, crome, hondata etc.
Check out: https://honda-tech.com/zerothread?id=1258100
Old Jul 9, 2005 | 01:21 PM
AllMotorDan's Avatar
a friend of mine was showing me uberdata and how to tune with it and it looks fairly easy and its really cheap too
Old Jul 9, 2005 | 08:05 PM
Default Re: (SpoonSirG)
so uberdata with this setup would be good???? and also is there anything else i ned to do to get the best out of these cams???
Eg6DR
30
Mar 12, 2008 05:08 PM
Liquidgsr
Apr 26, 2007 05:24 AM
da'ee
Feb 26, 2005 08:40 PM
myh22
Sep 17, 2003 09:59 AM
22civic
Aug 21, 2002 09:12 PM
