Welding stainless to mild steel?
Something like SS exhaust tubes to mild steel flanges MIG is fine, you could TIG them if you wanted to I guess.
Something delicate should be TIGed for best results, oil pans, thin sheet metals, etc.
Ive been welding all of my manifolds with a high-silicon stainless filler-metal for about a month now. Mild and Stainless. So far, no problems. But ya, Oil pans you want to be TIGed, anything else, MIG will do the trick.
This is for a downpipe (vband flange to 5 bolt flange). Has anyone actually done this, because I'd like some advise on how ot prep it, voltage, etc? I am going to be welding with a 110v Miller, and I can run either pure argon or argon/co2 mixed. Thanks.
Yeah, mild steel to mild steel is no problem. TIG will look better, but probably won't make a difference in terms of strength
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFrollingout »</TD></TR><TR><TD CLASS="quote">im about to mig weld a mild steel bung to the oil pan will that work. why dose it need to be tig welded just for looks or for strength.</TD></TR></TABLE>
doesnt have to be tig'd....but tig'd is stronger and looks better. if ur going to tig it, the make sure to use 309 filler (welding dissimilar metals). u can even use stainless wire on the mig too.
MIG&TIG production rate vs shear strength
Thanks Javier!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by javierb14 »</TD></TR><TR><TD CLASS="quote">doesnt have to be tig'd....but tig'd is stronger and looks better. if ur going to tig it, the make sure to use 309 filler (welding dissimilar metals). u can even use stainless wire on the mig too.
I don't have problems welding bungs or returns on oil pans or sheet via MIG. Play around with your machine, it just takes a little finesse.
viper_boy403
Welding / Fabrication
May 24, 2010 07:51 PM
BDogggUT34
Jul 30, 2007 12:03 PM
TrueUntilDeath.com
Feb 2, 2005 07:06 AM
filetofit
Nov 1, 2002 03:26 PM
