do you need a fuel pump strainer?
Old Apr 29, 2003 | 11:17 PM
HondaCutter's Avatar
Default do you need a fuel pump strainer?
just curious...
Old Apr 30, 2003 | 06:38 AM
88_SC_CRX_Si's Avatar
New User
Default Re: do you need a fuel pump strainer? (HondaCutter)
I would not mess with taking it off, the side effects could end up costing some very serious $$$$$. From partically(sp) clogged injector(s), causing a lean condition in one or more cylinders, and a hole being burned through a piston(s). Or just flat clogging the injectors, causing the engine not to run at all... hehehehe
Old Apr 30, 2003 | 07:28 AM
rolow's Avatar
I would not take the chance either.
It is meant to keep the big stuff out of the line so not to clog the line to the filter. Kind of like a pre-filter.
Old Apr 30, 2003 | 07:56 AM
raene's Avatar
Default Re: do you need a fuel pump strainer? (rolow)
Plus it actually acts to shift the intake of fuel lower in the tank, so the pump isn't left sucking air above the level of fuel
I wouldn't run without one!
j.bro
Honda Civic (2001 - 2005)
Jan 8, 2013 02:35 PM
GoldLudeRay
Sep 19, 2010 09:50 AM
JLHDOHC
Feb 10, 2007 08:16 PM
Gringo003
Dec 22, 2006 09:44 PM
cjb80
Jun 15, 2004 12:21 PM
