Possible swaps for an EF Civic hatch
Old Apr 29, 2003 | 09:23 AM
darren p.'s Avatar
Default Possible swaps for an EF Civic hatch
I'm doing research for my brother, who is looking to get a '91 civic hatch. I've been searching on this site but haven't found too much about possible swaps into the 4th gen civic hb. I'm a VW guy but I know a decent amount about Honda. I'm thinking of a B18c1...what do I need to complete the swap? I'm assuming mount kit, axels, ecu/harness...anything else? Thanks in advance! Any suggestions on other possible swaps would be appreciated.
Old Apr 29, 2003 | 12:41 PM
truent's Avatar
Default Re: Possible swaps for an EF Civic hatch (15 degree V)
anything. everything will work, just a matter of how much work you wanna put into it.. checkout
http://tech.hybridgarage.com/t....html
they have a list of a few.. matter of difficulty/what you need etc
what model hatchback is it? dx/std/si? if its dx or std.. you're gonna haveta do a lil wiring.. but none of it is really that complicated especially if you got a lil experience, good luck..
Old Apr 29, 2003 | 01:15 PM
poison's Avatar
Any B series with a mount kit will work. I would recommend looking into a 1st gen B16 though.
HTH.
Old Apr 29, 2003 | 01:42 PM
Dmotor2nr's Avatar
Any civic motor or integra motor will work. If you want to get real crazy the h22a will also fit with some work. Honestly B-series engines are great for power but they and their parts are unbelievably expensive. If you want a fast car I would stick with the stock motor- 1.6L sohc d-series and build a turbo for it. It will be a lot lighter than the swapped cars and if you blow up the motor you can pick up another one for a couple hundred bucks, unlike the b-series which may cost you more than a thousand or more depending on the kind. The dohc 1.6L NON-VTEC(zc) could also work really well with a turbo, and they are also cheap.
I guess it depends on how much money you wish to spend overall.
Old Apr 29, 2003 | 07:57 PM
H22CRX's Avatar
Default Re: Possible swaps for an EF Civic hatch (Dmotor2nr)
I'm thinkin go with a H22....on second hand don't it's a ****. B-series
Old Apr 29, 2003 | 08:00 PM
koco's Avatar
The bad thing is motor mount kits seem to be over $600. Otherwise it looks worthwhile. Is there any way around the hefty motor mount price tag?
I think a D16Z would fit in there for low cost.
Old Apr 29, 2003 | 08:16 PM
H22CRX's Avatar
Default Re: Possible swaps for an EF Civic hatch (koco)
Make them urself..that's what I did
Old Apr 29, 2003 | 09:50 PM
1st-hybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koco &raquo;</TD></TR><TR><TD CLASS="quote">The bad thing is motor mount kits seem to be over $600. Otherwise it looks worthwhile. Is there any way around the hefty motor mount price tag?
I think a D16Z would fit in there for low cost.</TD></TR></TABLE>
600 for a mount kit????? I got my HCP kit for much less, don't buy the first one you see shop arpund they can be found for a lot cheaper.
gnomesxo
Nov 9, 2017 04:26 AM
Boolin_ED6
Engine Management and Tuning
May 31, 2017 08:23 AM
TheGoldenNugget
Feb 24, 2017 09:29 AM
darren p.
Apr 29, 2003 11:14 AM
