Spoon cams, worth the extra moolah?
Old Jul 2, 2001 | 12:35 PM
ninjaman's Avatar
New User
Default Spoon cams, worth the extra moolah?
I found a set of spoons for $850. Does anyone think/not think it's worth the extra money over a set of Skunk2 cams for $670? In comparing, the Spoon's have more lift but a little less duration than the Skunks, which equals more midrange torque.
Please don't tell me to get Toda's, I don't want to go that extreme/expensive.
Old Jul 2, 2001 | 12:38 PM
Kengs's Avatar
Default Re: Spoon cams, worth the extra moolah? (ninjaman)
Why not? Toda As are just a tad more $$$.
Old Jul 2, 2001 | 12:49 PM
6SPD_EK's Avatar
Default Re: Spoon cams, worth the extra moolah? (kengs)
toda a's and spoon cams are VERY similar, I am in the same boat as you - but I'm looking for spoon cams, if I were you I would go with the spoon cams, but you may not get as much as you hope to get out of them (HP wise) without other mods
Old Jul 2, 2001 | 09:17 PM
ninjaman's Avatar
New User
Default Re: Spoon cams, worth the extra moolah? (2000-4DRGSR)
I'm still deciding, but I'll probably throw them in with a VAFC, cam gears, 64mm TB, and Skunk2 Intake manifold and see how they run for a bit. (Stage 1) I already have I/H/E and 98 Spec R tranny, and am ready for more power.
Later this year, I'll be sending my head off to get it ported and polished and boring my block out to 2.0, putting in some hi-comp pistons (11.1-11.5), get an SMSP header, and new ECU. (Stage 2)
I've still got to do some research to see how much cheaper to do it all at once, and that will convince me whether I should wait or do it in stages as I have planned. By the way, does anyone know what a reasonanble rate is to get cams, valve springs, retainers, timing belt, and water pump installed? (Not including parts).
Old Jul 2, 2001 | 09:42 PM
Padawan's Avatar
Darth ModerVader
Where did you find the Spoons for that price? Are these new?
Old Jul 9, 2001 | 07:45 PM
ninjaman's Avatar
New User
Default Re: Spoon cams, worth the extra moolah? (SpecR0123)
Sorry I left you hanging for so long on this one. They're new and I'll let you know the place as soon as I found out it's a legitamate deal. (Don't want to mislead you if it falls through)
Old Jul 9, 2001 | 08:01 PM
Padawan's Avatar
Darth ModerVader
Thanks - keep me posted.
jansenrw
Mar 9, 2005 03:57 PM
dabomb
Mar 22, 2003 05:03 PM
Drag-On
Oct 17, 2002 12:46 AM
capcon83
Aug 7, 2002 03:35 AM
alexboy
Aug 28, 2001 08:35 PM
