another new problem (coolant system related)
not sure fan is turning on . I used a thermo. housing from a 92 gsr on my b18 c5 in a 91 si . What i did was spliced the harness from where the original thermo switch wires were and put a clip from another harness which plugged into the 92 gsr thermo housing . Shouldnt doing that work to make the fan turn on automatically? Also the overflow tank is bubbling very violentley . Also noticed the upper rad. hose is VERY soft and flattens out. Im changing the hose in the A.m. Any ideas guys.
thanx >>>e
thanx >>>e
even with you fan not turning on it should over heat..i drove with a working fan for at probably a full year or more! temp went up and down but never past half point. Even after a couple of 8000 rpm ragers then sitting in parking lot trafic on a hot summer day it never went past half point!! ..until (
) my thermostat went bad..got it fixed everything back to normal....
maybe check your thermalstat....
) my thermostat went bad..got it fixed everything back to normal....maybe check your thermalstat....
i wired up the fan to ignition and it seems to be working, i cant realy tell cause i keep having alternater problems (shitty aftermarket rebuilds ), Goin on # 3 . Not sure if i need a thermostat or not cause my blower motor took a **** but i dont need heat right now so who cares . I luv spring
Ill keep ya guys posted. Thanx >>> e
stealth civic
Jan 13, 2005 09:03 AM
urzaofusn
Jul 8, 2004 05:50 AM
