do i need a new clucth???
Old Apr 28, 2003 | 07:14 PM
1quik95gsr's Avatar
Default do i need a new clucth???
I was racing the other day and i grinded second gear so i lined up again and went at it again and the same thing happen maybe it was bad shifting but now everytime that i drive second gear is hard to put in and everytime i wanna race second gear grinds and have to force it in. Does that mean that i need a new clutch? I've had that cluth for over a year, by replacing the clutch will second gear be smooth???? thanks in advance!!!
Old Apr 28, 2003 | 07:34 PM
jeiden's Avatar
change your tranny fluid
Old Apr 29, 2003 | 07:02 AM
vadim's Avatar
Default Re: (jeiden)
you do not need a new clucth. on your secand gear your syncro is **** up so it is hard to put in gear. you should adjust the clucth padle or 10w30 mobil motor oil for the tranny. it is not a big thing just do that and you should good.
Old Apr 29, 2003 | 07:26 AM
tilt's Avatar
Default Re: (vadim)
easy way to tell is if it's just one particular gear or all of them. one would indicate synchro, all would point to clutch.
dpine
Feb 26, 2007 07:06 PM
edunnett
10
Sep 10, 2004 09:32 AM
sshaikh01
17
Mar 6, 2003 06:27 PM
Brandon
Jul 31, 2002 09:59 PM
