having trouble with jdm b16A swap!!
Old Apr 28, 2003 | 03:43 PM
wooderson's Avatar
Default having trouble with jdm b16A swap!!
i have a 6th gen hatch dx with a jdm b16 second gen. and after i bolted it up i have to many plugs left over, and i dont know what to do now. am i going to have to buy a new wire harness or what. im using the stock dx harness right now. in reading previous articles on this particular swap it is not recommended to use a jdm b16, is that a bunch of **** or is it true? any info would be helpfull. thanks.
Old Apr 30, 2003 | 08:40 AM
allmtr's Avatar
Default Re: having trouble with jdm b16A swap!! (wooderson)
thats a bunch of ****. im using one right now and it was easy...
Old Apr 30, 2003 | 08:59 AM
Trey's Avatar
25 Year Member
That's because you are using an OBDI motor in an OBDII car. OBD II uses more sensors. You will need to use an ECU harness converter to run the OBDI ecu in your car with the OBDII engine harness. The OBDI ecu won't look for the OBDII sensors and you will be fine.......
You should have gotten an OBDII swap and it would have been all plug and play......
Glowicki
20
Oct 8, 2013 04:26 AM
dc2doi
Oct 13, 2007 07:21 AM
h22_crx
Aug 10, 2007 10:10 PM
Type RS
Nov 16, 2002 01:28 PM
