my clutch was acting weird!
Old Apr 28, 2003 | 10:19 AM
redteg1's Avatar
Default my clutch was acting weird!
when i got into my car today i pressed down my clutch to start my car...but the clutch was very hard to press. esp. when getting closer to the bottom. it felt sorta vibraty/shaky/gritty towards the bottom...sorta hard to explain. the gears were very hard, almost impossible to shift into. i finally got it into reverse...but i couldnt get out of it! so i decided to shut off my car before i start driving....and then..voila everything returned back to norma...i just thought htis was weird and wat could've caused it. any ideas or help thanks.
Old Apr 28, 2003 | 01:27 PM
redteg1's Avatar
Default Re: my clutch was acting weird! (redteg1)
ok here's wats happening. car wont go in gear once started...but the car will go into gear when its off...yet when i turn the car on...(foot on clutch all the way pressed to the bottom.) the car will start to move forward and when ebrake is up the front will move up almost like im letting off the clutch in first...then car will shake and stutter down till the rpms go down and stall out. WATS GOING ON?!?! my car is 95 gsr btw.
Old Apr 28, 2003 | 01:55 PM
redteg1's Avatar
ttt
Old Apr 28, 2003 | 01:58 PM
.RJ's Avatar
.RJ
how many times do you need the same answer?
Once more.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">the springs on the clutch hub have failed. you need a new clutch.</TD></TR></TABLE>
Old Apr 28, 2003 | 02:02 PM
redteg1's Avatar
Default Re: my clutch was acting weird! (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">how many times do you need the same answer?
Once more.....
</TD></TR></TABLE>not that many times...as with anything it is good to get a second opinion thats all.
Old Apr 28, 2003 | 02:04 PM
.RJ's Avatar
.RJ
ok have fun with that. doesnt change the facts.
Old Apr 28, 2003 | 02:19 PM
redteg1's Avatar
slave/master cylinder maybe?
Old Apr 28, 2003 | 03:11 PM
.RJ's Avatar
.RJ
uhm..... nope, not likely.
Your clutch is busted dood. I've had friends who's clutches have gone out with identical symptoms. Your clutch cant disengage while the motor is running (i.e. clutch spinning).
Old Apr 28, 2003 | 03:18 PM
redteg1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">uhm..... nope, not likely.
Your clutch is busted dood. I've had friends who's clutches have gone out with identical symptoms. Your clutch cant disengage while the motor is running (i.e. clutch spinning).</TD></TR></TABLE> gears wont engage while car is running. gears go in fine when car is turned off though if u are thinking of something different, no?
Old Apr 28, 2003 | 03:20 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redteg1 &raquo;</TD></TR><TR><TD CLASS="quote"> gears wont engage while car is running. gears go in fine when car is turned off though if u are thinking of something different, no?</TD></TR></TABLE>
Thats what i mean. You cant put it in gear because the clutch wont disengage while the motor is running. When the motor is off, the clutch isnt spinning around and you can slide it in to gear since the gears in the trans arent spinning with the motor.
Old Apr 28, 2003 | 04:12 PM
redteg1's Avatar
ohhh ok i see wat ur saying....now i understand...thanks man
SIC_jdm_da9
May 20, 2010 11:26 PM
SonicRacing
Feb 26, 2006 01:54 PM
BIGthings
13
Feb 19, 2006 09:15 PM
redteg1
Apr 28, 2003 04:50 PM
OneSlyTeg94
Jul 11, 2002 11:11 AM
