FP on a GSR
Old Jul 1, 2001 | 04:20 PM
hondamanwill's Avatar
Default FP on a GSR
need to know what the stock fuel volume is on a 99GSR not the fuel pressure but the volume. i put a 99GSR motor in a 99 Civic hatch.but i think i need to change the fuel pump.
Old Jul 2, 2001 | 10:19 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: FP on a GSR (hondamanwill)
Yes, you should change the pump for best results. FP is between 48-54psi
Old Jul 3, 2001 | 09:51 PM
TypeC's Avatar
Default Re: FP on a GSR (Aj.)
now way! stock is btwn 38-42 with the hose on. HTH, -C
Old Jul 3, 2001 | 09:59 PM
FSTASNTZ's Avatar
So far all the hatchs I have seen do not have a fuel pump that can supply the B series VTEC engine with enough fuel.
I am not sure of the flow rating. I do know with the B18C1 and the hose disconnected, it runs stock at about 50 PSI.
The last hatch I saw on a dyno had a B20VTEC and the stock CX pump was failing at about 42 PSI.
Jason
schpiel
Jul 10, 2008 01:08 PM
CFDOHCVTECEG
Feb 2, 2007 03:32 PM
JUGGIEGAILS28
Feb 19, 2004 12:09 PM
echo999
Mar 8, 2003 12:35 PM
SuperRice
Jul 5, 2002 01:45 AM
