My poor sick R
Old Apr 27, 2003 | 10:13 AM
RRRex's Avatar
Default My poor sick R
So I blew blue smoke at the track yesterday. Crap. It also blows a bit when I first start her up. So sad. Don't know how much time my baby's got left. Going to do a compression test and a leak down soon. And probably install an oil catch can to see if it helps. Before committing to a pricey overhaul what other cheaper things can I try?
Old Apr 27, 2003 | 10:25 AM
Tommy_Gunns's Avatar
Default Re: My poor sick R (RRRex)
I doubt an oil catch can will help any.
Old Apr 27, 2003 | 11:52 AM
rated_r's Avatar
Default Re: My poor sick R (zyg)
poor thing
Old Apr 27, 2003 | 07:51 PM
RRRex's Avatar
Default Re: My poor sick R (rated_r)
Aside from thicker oil, changing fluids more regularly, is there anything else I can do to keep her going a little longer?
Old Apr 27, 2003 | 10:54 PM
CunninLynguist's Avatar
Do you have an R?
Old Apr 28, 2003 | 05:16 AM
RRRex's Avatar
Default Re: My poor sick R (Scot project)
I have an R motor in a CRX. I know this is the Type R forum but it is the motor that I'm looking for advice on.
Old Apr 28, 2003 | 05:32 AM
Philly_NBP_R's Avatar
You might want to try something called "Engine Restorer" - it comes in a metal can. My friends and I have seen wonderful things, and it's only like four dollars at your local Pep Boyz. Probably the best oil additive out there, and the only one that actually makes a difference. Add it after an oil change.
Old Apr 28, 2003 | 06:54 AM
RRRex's Avatar
Default Re: My poor sick R (Philly_NBP_R)
Did a compression test and I've got 250lbs in each cylinder. That tells me there's oil in the cylinders sealing the rings creating extra compression. But since it's the same across all the cylinders tells me that maybe it's the valves? What would a leakdown test tell me?
Old Apr 28, 2003 | 07:56 AM
Those numbers seem kinda high:
https://honda-tech.com/zerothread?id=489116
I'll be doing a leakdown test myself soon, I would try a search for more info though...
Old Apr 28, 2003 | 08:04 AM
RTW DC2R's Avatar
something is fishy.
maybe you need more nawz.
Old Apr 28, 2003 | 08:38 AM
RRRex's Avatar
Philly_NBP_R: Thanks for the link. I was reading that earlier.
I know oil is getting in there somehow and the oil is clogging the rings somehow hence the good bit of smoke in Vtec. I'm praying it's the valves. I'll post the results of the leakdown when it's done.
Old Apr 28, 2003 | 09:21 AM
My first guess would be valve seals - theyr'e not to hard to replace, but you may have to pull the head...
Old Apr 28, 2003 | 09:32 AM
TypeR 01 886's Avatar
how many miles does the "engine" have on it? do you know?
Old Apr 28, 2003 | 10:03 AM
RRRex's Avatar
Default Re: My poor sick R (TypeR 01 886)
It's been abused. It's a 98 USDM motor. No one ever buys a Type R to be gentle so I'm pretty sure it's taken a beating. It came with "40K" on it (don't they all!?) out of a wreck, so chances are it's not a lady driven daily driver. All used type R motors are a risk no matter what the mileage just because of the abuse they tend to take. Aside from being told it was a low mileage motor I got to honestly answer I have no idea. Compression was fine when I bought the car and it's still equal across all cylinders so I'm hoping it's still a strong motor.
Old May 6, 2003 | 06:01 AM
RRRex's Avatar
Took the car for a leakdown and the valves are sealing fine. Did the compression again, both wet and dry this time and here are the results:
Cylinder#1:
Dry : 185
Wet: 235
Diff: 50 psi
Cylinder #2:
Dry: 190
Wet: 230
Diff: 40psi
Cylinder #3:
Dry: 190
Wet: 210
Diff: 20psi
Cylinder #4:
Dry: 190
Wet: 210
Diff: 20psi
Obviously 1 & 2 are having "issues". Is there anything other than taking it apart to keep it going longer? I've switched to a thicker oil and am just going to keep an eye on the oil levels for now.
jmv38
Mar 24, 2006 08:59 PM
otakueric
Mar 3, 2004 08:27 PM
silvlude
Jul 31, 2003 05:12 PM
EF-9SiR
Dec 16, 2002 11:14 PM
shermanyang
Aug 5, 2002 05:11 PM
