GSR deck plate block "pictures inside"
GSR 5/8" Deck plate bare block, comes with 5/8 of a inch deck plate, Brand new GE sleeves, all caps, oil pan, oil tray, and oil pick up, ready to install pistons and rods. This block is good till for 81mm to 87mm bore. also you'll be able to use a bigger crank and longer rods, grea for boost because of better rod stroke ratio
price: taking reasonable offers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrboGSR »</TD></TR><TR><TD CLASS="quote">bump for a nice block. what are ya lookin to get for this thing?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brekekex »</TD></TR><TR><TD CLASS="quote">Just curious:
what t-belt is to be used with this block?
Thanks.
-Tom</TD></TR></TABLE>
I was wondering the same thing as well as how the deckplate seals in the oil between it and the block...I am building a similar height block but can't seem to figure that one out. Bump for a beautiful block...I just hope mine comes out looking that good...
-Ryan
EDIT-Looks like there is a gaket there...
Thanks.
-Ryan
timing belt you need custom if oyu dont get the aftermarket water pump from GE
The water pump placement makes the difference the actual block of plate they make with the pulley
b18bturbo is right.... you can use a offset gear or water pump for that block and you'll be able to use stock gsr timming belt
per4mance
Jul 25, 2010 05:18 AM
per4mance
Southeast (Sales)
84.5MM Dart Block, Endyn RW Pistons w/ raised pin @ 13.5:1 Endyne Long Rods, Endyne Modified Oil Pum
Christian
Sep 1, 2004 05:16 PM
nice pic of your block
