No Brake Lights..NEED HELP! ASAP
Ok here is my situation I have no brake lights. I do have tail lights and dash lights and all other lights working just brake lights dont work. Well this is my only car as of now and its getting a paint job monday so I gotta do it tommorow. Is there a Fuse or just the brake lights I know there is one for the tail/instruments. Im stumped on this and it makes me mad but I know some HT member has had this prob or knows a fix. Btw the only electrical thing i disconected recently is the rear washer motor. Please help me guys
I checked that part. I had took out my horn fuse a while ago. I went out and put a fuse back in there and I have brake lights again. Is it possile my brake lights will work with out the horn fuse in? I took it out cause drains my batt.
brake lights and horn are on the same fuse...if you are taking out the fuse then you won't have brake lights. when you reinstall the fuse are the brake lights on without touching the brake pedal? if so, then check to see if the plastic stopper on the brake pedal is gone...this is what pushes on the brake light switch when you release the pedal. it is common for these plastic stoppers to break after so many years. if yours is broken you can get one from honda. HTH
everything works fine with the fuse in. Is it possible for the brake lights to work with out the fuse in? Im just curious cause if so I have not had brake lights for like six months
My g/f sad i had working but ya know girls
how exactly did you disconnect the wiper motor? cut wires or unplug? is there a short from the ground there? you might try grounding the plug for the wiper motor, (ground wire only, not anything with voltage.)
I<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndhandCRX »</TD></TR><TR><TD CLASS="quote">how exactly did you disconnect the wiper motor? cut wires or unplug? is there a short from the ground there? you might try grounding the plug for the wiper motor, (ground wire only, not anything with voltage.)</TD></TR></TABLE>
I discontected the wire and un bolted the wiper motor. Im getting th car painted so I took it off. Its just wierd if I had been drivin 6 months like this Im lucky. Thanks for helping me out
when I get the car back Ill hook up the wiper motor and see if it happens to be a problem
I got em to work only when the horn fuse is in. I pulled the fuse out before because something on that wiring harness had a drain when I used a test light. I didnt figure the Horn and brake light deal would be on the same deal. I cant figure where the drain is since my car is at the body shop. Im gonna look at my HB to get any ideas of where a bad ground could be. Its just wierd to me that the horn and brake lights are the same wiring thing
MR Rodgers
Jan 5, 2009 02:32 PM
