ls or h22
i am interested in knowing your opinion about the two motors should i do a ls turbo or prelude h22 turbo in 96 hatch dx does any know any times for the two or opinion thanks guys
it all depends on how much work you want to do also.....the H22 is going to be more work to install but will be worth it in the end, and the LS is just a basic drop-in swap.....its all about time, money and effort....be realistic with yourself though....good luck....
you can get either setup to run 13's. You can get either setup to run 12's. You can get either setup to run 11's.
How thick is your wallet?
Really, your questions are too vague.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-cRx »</TD></TR><TR><TD CLASS="quote">the main question is is it worth spending the extra cash to have a h22 turbo or should i go with the ls turbo </TD></TR></TABLE>
if you have the cash and want to wow people when you pop up your hood go h22 turbo...either setup will set you back alot of money. damn i wished i had cash to turbo my car
Alright you guys, listen you cant' compare an h22 to an ls. Ls equals non-vtec, h22 equals vtec. do you want it or not. thats one question. Next, h22 costs a little more and requires a little more work, I should know i've done three seperate ones ( and pulled out and re-installed to many to count) including my own. requires custom wire harness mount kit etc.. H22 is definately worth it. right now i'm running 13's w/ i/h/e, fuel rail, fp, and fpr. and for you people that don't know waht your talking about the car doesn't even know the motor is there, meaning its not any harder to turn. I'm going to autox this year so i'll let ya know how that goes. Good luck w/ your descision.
I would go with the lude motor, your will run low 14's on stock motor.... or better.... can't go wrong with that
