Help blowing fuses!
Old Apr 26, 2003 | 07:15 PM
brent_G's Avatar
Default Help blowing fuses!
Alright my fuse for my running lights, dash lights etc...well its in my 88 crx si wiht ls swap...everytime i turn my runnign lights on they blow...
Ive tried higher amp fuses...30
ive checked a million grounds...dindt work
CHecked my runinngs lights front and back nothing crossing or touching.
Checked my radio to make sure nothign was grounded out...
still blowing fuses...i cant drive at night i need my caR!!!! any ideas?
Please
Old Apr 27, 2003 | 05:45 AM
seekerONE's Avatar
let me guess....you have aftermarket radio?
i have seen this where i work about a hundred times. the adapter harness that plugs into the factory harness has a wire on it that gets power from the dash lights and since most aftermarket radios don't use this wire it is usually just left loose. when it finds a ground(almost any metal in the dash) it shorts and blows the fuse. if this is your case then check the wires on the back of the radio...most of the time the wire fron the adapter harness is orange. tape off the end so it won't touch anything.
Old Apr 27, 2003 | 02:04 PM
brent_G's Avatar
Default Re: (seekerONE)
no aftermarket radio...its all stock wiring...
Old Apr 27, 2003 | 03:33 PM
seekerONE's Avatar
damn, that is usually it. ok, any aftermarket taillights, or indiglo instrument lights?
Old Apr 27, 2003 | 03:47 PM
Hondasaurs's Avatar
Default Re: Help blowing fuses! (screamincivik)
Did you smell anything burning or see any smoke? Something internal (not visible) may have melted causing a short circuit.
Old Apr 27, 2003 | 04:09 PM
brent_G's Avatar
Default Re: Help blowing fuses! (ZC_CRX)
No everythign is completely stock....the only thing i had was a af fuel guage...but. i took all of it out to make sure... nothing makes sense to me....
Old Apr 28, 2003 | 06:31 PM
brent_G's Avatar
still nothign guys...any more ideas? i have 91 tails in my 88si...but thats all grouded good...even added an extra one yesterday...i really hate buying new parts to find the problem...its just a big expensive guessing game...
Old Apr 28, 2003 | 07:57 PM
seekerONE's Avatar
the problem isn't a lack of ground...it is a short to ground.
Old Apr 28, 2003 | 08:03 PM
brent_G's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seekerONE &raquo;</TD></TR><TR><TD CLASS="quote">the problem isn't a lack of ground...it is a short to ground.</TD></TR></TABLE>
either way...so far no bare wires...im gonna try a new steering wheel column where the switch is for my lights and what not...then if that dont work...fuse box...here we go guessing
Old Apr 29, 2003 | 10:29 PM
brent_G's Avatar
Default Re: (screamincivik)
replaced steering column and fuse box today...made no difference
"HELP!"
Old Apr 30, 2003 | 07:51 AM
redzcstandardhatch's Avatar
something different
damn brent......that sucks big time. i'm having problems with my old lights too......the interior and running lights dont come on until the feel like it. sometimes they pop on after about 4 minutes, sometimes never. have you checked relays? it kinda sounds like you might have a fried relay, but i cant say anything for sure
Old Apr 30, 2003 | 09:51 PM
brent_G's Avatar
Default Re: (redzcstandardhatch)
well if the relays that run on that system are on the fuse box at all then that aint it...i dont know much about wiring thats why this is soo frustrating...everythign else im alright this stuff is overwhelming to me
Old Apr 30, 2003 | 10:48 PM
Ham'ed Hatch
Guest
Posts: n/a
i've had this problem for a couple years now. i took it to a few shops and they couldn't tell me anything. so one day i tapped into the red/black parking light wire, hooked up a toggle, and ta-da! they work.
but if you want to find the short, take out the blown fuse, hook up a multimeter to the fuse slots. then wiggle harnesses that contain a wire linked to the fuse and watch for the voltage to spike. it'll give you the general area.
HTH
Old Apr 30, 2003 | 11:18 PM
RuthlessEF-9's Avatar
Default Re: (Ham'ed Hatch)
i had this problem alot cause i had alot of ****** riggin **** in my car like gauge lights (autometer) what i always did was tweek my back and just look for any loose wires hanging. and check your parking light wires see if any of them came off over time due to wear
Old May 1, 2003 | 06:09 AM
IamVtec's Avatar
this also happened to me before, there was a loose wire touching a ground and melted my dash wires from the parking light swtch all the way to the radio. I had to pull the dash off and replace the burnt wires.
You should pull out the radio harness and check out all the wires running through the dash and to the switch, just to make sure. FOr a fact theres a loose wire that is touching metal and it just blows the fuse each time it is turned on.
Old May 1, 2003 | 08:18 AM
brent_G's Avatar
Default Re: (Full Throttle EF)
thanks guys...thats a lot more input then i expected to get...ill have to try that out when i get some time to rip it all apart...any more feeback would be great thanks
Old May 1, 2003 | 08:31 AM
CRzex's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screamincivik &raquo;</TD></TR><TR><TD CLASS="quote">Ive tried higher amp fuses...30
For future reference its not really a good idea to use higher amp fuses than whats recomended, thats how fires start. Also you said something about removing a AF gauge, when you installed it did you splice into any wires? Because when you removed it if you left any bare wire exposed that could cause problems too.
Old May 1, 2003 | 08:42 AM
brent_G's Avatar
Default Re: Help blowing fuses! (CRzex)
i followed all those wires...taped them if they were bare...pretty much just removed anything that i think could make it do this...thats what its all a mystery right now
Old May 1, 2003 | 10:06 PM
brent_G's Avatar
up for me please...
Old May 1, 2003 | 10:18 PM
Louie B.'s Avatar
has it been raining lately? I've seen bulbs crack and get water in them before... it's a shot in the dark, but try pulling each of your bulbs out and test them.
Old May 2, 2003 | 06:50 AM
brent_G's Avatar
Default Re: Help blowing fuses! (thumpu77)
yeah i just checked again...they are all doin just fine in that department...thanks tho
Old May 2, 2003 | 07:06 PM
brent_G's Avatar
well as of the moment fuses arent blowing...but it has happened before...my car will get my hopes up and then snap a fu se will blow...i think i found it tho...the wire harness in the dash that was behind the cluster...well the harness was getting pinched between the dash and the metal frame....and there was a red wire that was indeed spliced a lil bit on the metal part which infact would be a ground for the car...so hopefully that was it...cause im itching ti installl the ef8 sidemarkers...
ej9071
Audio / Security / Video
Oct 2, 2017 01:56 PM
ONE-CAM-EF
Jan 2, 2009 07:06 PM
Psychoteen101
Dec 17, 2008 11:41 PM
accordguy2001
15
Feb 11, 2008 10:43 AM
accordguy2001
Feb 1, 2008 09:40 AM
